Old 09-24-2006, 12:26 AM   #1
Hydraulic brake maintaince
For those of you that have hydraulic brakes you might be able to save some time and money from my experience.
Just a few days ago I noticed a puddle of brake fluid forming under the bus. Upon closer inspection I discovered it had all leaked out. It turns out the master cylinder is in bad shape.
The master cylinder is full of rust and the inside is staring to get pitted. The pitting allows fluid to seep past the O-rings. I am hoping the damage is not so bad that I need a new master cylinder. I was quoted by NAPA $216.00 for a new one.
Of course all this could have been avoided if the school district and the previous owner had changed the fluid regularly. The fluid is nearly as dirty as the engine oil. It is full of rust and corrosion.
busone is offline   Reply With Quote
86 International Hydraulic Brakes hmacris International | Navistar Drivetrain 4 07-31-2022 10:40 AM
Air vs. Hydraulic pangaia Brake Systems and Air Brakes 14 09-09-2021 11:17 PM
tractor hydraulic fluid, can I use it? jlhollowx13 Mechanical and Drivetrains 6 08-04-2013 08:46 AM
1991 BlueBird TC2000 Hydraulic/Hydraulic Brakes Sticking C00LR Mechanical and Drivetrains 0 10-15-2009 10:11 AM
hydraulic to air brakes adamanderr Conversion General Discussions 2 01-03-2008 10:35 PM
