03-24-2007, 12:28 PM
Rated Cap: 60
I need some shower advice! Post pictures of your bathroom!
I'm in the process of planning out my bus. I've been to Home Depot and Lowes several times for inspiration and to get prices. On just about every aisle at lowes, I find something that could serve a purpose on my bus. Anyways, I'm curious about what you all have done for your showers. I'm planning to frame mine up, use some pressure treated ply for the walls, and then line it with that paneling that looks like tile. I'm just curious what I should use for the shower base. I might just build it up and use some sort of tile. I'd also like to have a shower door and not a curtain. Also, how big are your showers? I'm planning a 36" x 36" shower for my bus. Thanks for any advice or pictures!
03-24-2007, 04:24 PM
Engine: 5,9 Cummins
Don't know if this will help, but I'm installing a 36x36 one piece fiberglass stall. Seems
like a major time saver compared with fabricating from scratch. Cost $250,-.
03-24-2007, 09:26 PM
Not sure what kind of tile base you're talking about, but if it's the type you have to grout in to make it water tight...the vibrations and flexing of the bus are likely to make that stuff crack...
You probably should just buy a shower base, Lowes has a 32x32 base for $98 or so...
I've got limited space and not real likely to use the shower in mine, I prefer to use campground facilities so I don't fill the gray tank in one use... As such, I've been looking at some one piece shower bases on ebay stores, found a nice 24x30 for only $42 plus shipping.... I'll probably just go with that....
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
03-25-2007, 08:44 AM
Year: 1985
Chassis: International S1800
Engine: 9.0L Diesel
Rated Cap: 54
I saw a picture in my journey's around the web of a skoolie that someone had taken a stainless steel deep kitchen sink and cut a hole in the floor of the bus and welded supporting brackets to hold it. This added nearly a foot of overhead to the shower (something I need at 6'2") and made a narrow stand up shower. I thought it was a pretty slick idea and is what I'm planning on doing in my rig. I'll look around and see if I can find it. I lost a lot of bus info and pictures when my hard drive crapped out a few months back!
03-25-2007, 11:48 AM
Engine: 7.3 diesel
I think the one you are refering to is on this site.
Here is the gallery
http://www.skoolie.net/gallery2/v/Sk.../Andy-B-Bus-9/
03-25-2007, 07:02 PM
Year: 1985
Engine: 9.0L Diesel
Rated Cap: 54
BINGO wmah! Thanks! Being a little on the tall side I thought that looked like a really great idea.
03-25-2007, 09:15 PM
Coachwork: Ward Genesis
Engine: DT466/MT643
My shower pan came from an apartment building being renovated (total cost: one 20-pack of really bad beer )--it's a kind of oddball 32x36". I sunk it about 8" into the floor for headroom...it drains with an electric pump (through a filter) that's basically a boat bilge pump.
Jarlaxle
03-26-2007, 12:57 AM
Engine: 5,9 Cummins
:P
This thread asks us to... Post pictures of your bath room!
I think I did quite well, actually, restraining myself for several days.
Ahhh, to be that young again. Notice it's a black'n'white photo! No, that's not me. I took the picture.
Paaaaarrrrtyyyy!!!!
03-26-2007, 01:02 AM
Well....atleast they found the toilet. To be perfectly honest, it was a point of much discussion as to whether or not we were going to have carpet on the floors for that exact reason. I just don't think anyone wanted anything to do with the portapotty though and went outside.....
For all those with fiberglass tubs...any issues with cracking or leaking around the edges due to the movement in the bus?
03-28-2007, 09:04 PM
tub
I have a large fullsize one piece tub/shower surround from home depot. No cracks yet in 3 years of use but I made sure to brace it very well at side walls, I also shimmed the floor of the tub with small strips of wood to ensure even distribution of weight.
I actually made a mistake in measuring the unit when I purchased it for my bus and ended up having to cut a hole in the roof to drop it in!!
In search of Bus #2
(Sold)1989 Chevy Thomas 8.2 Detroit Allison AT545 Custom 3rd door added in back.
GM Service Tech
03-28-2007, 11:18 PM
Engine: 5,9 Cummins
...cut a hole in the roof to drop it in!!
One of my Kinetic Racing team members wants to be able to shower under the
stars when we go to races in Millicent. I'll tell her of your solution!
04-01-2007, 10:57 PM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Why? You have those double doors in the back of the bus. How did you do that door setup? We want to know. At least I do. Give it up.
04-02-2007, 05:19 AM
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
I'm guessing the shower install occurred prior to, and was a catalyst for the addition of the extra door!
