Old 02-06-2013, 10:15 PM   #1
Chassis: Blue Bird
Engine: DTA360 Spicer 6+1 Manual
I think it will work...Steel gauge
I pulled the interior roof skin off of my BB and measured it at about .0310 or .0315 (22 gauge?).
I think this will work out awsome for window skin. I know it is a little on the light side and I need to check my measurments to be sure I have enough but I think it will work. The stuff from the walls is to thin but the ceiling is a little better. Most people seem to prefer 18 or 20. If I have to add a cross brace horizontally in the middle of each window section and tack or rivet a few times that is worth the 2 or 300 in steel. Plus it is pre painted so rust shouldnt be a problem right away.
If I was buying it I would go a little heavier but for free you cant beat it. Besides I think it is the same guage as the rest of the exterior (correct me if I'm wrong I havent measured.
What do you think??
Thanks In Advance
Tony
rex_1_mn is offline   Reply With Quote
Old 02-07-2013, 10:08 AM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: I think it will work...Steel gauge
We used a heavy roof flashing, which isn't very heavy. We cut it by scoring it several times with a razor knife. We backed it with 1" rigid foam insulation. It's holding up okay.
Even survived a little hailstorm with no dings.
Fulltime since 2006
What gauge body metal? lornaschinske Everything Else | General Skoolie Discussions 10 08-28-2012 05:25 PM
Gauge size between batteries and converter? freedom_eagle Alternative Fuels | Electric, Propane, Wood & Biofuels 5 04-06-2012 09:33 AM
New door... would 32" exterior steel or fiberglass work? TygerCub Conversion General Discussions 14 01-29-2011 12:26 PM
New gas gauge? Seeria Mechanical and Drivetrains 2 07-28-2010 11:08 AM
Transmission temp gauge the_experience03 Conversion Tutorials and How-to's 1 05-10-2008 04:57 PM
