Old 05-12-2017, 02:38 PM   #21
tobeamiss's Avatar
Originally Posted by mysty View Post
To answer the original question, though, my wheel wells are in the area I want to put the kitchen. To best use the space, I am putting a closet/pantry over the wheel well on the passenger side, and a counter/cooktop over the one on the drivers side.
Yup, that's a plan I've been thinking of.
oh yes she did!
https://www.skoolie.net/forums/f11/to...-it-16557.html
Old 05-12-2017, 02:41 PM   #22
tobeamiss's Avatar
Originally Posted by Ryannmelis View Post
I dont mind the walk through shower. I am making a wooden grate to insert when the shower is not being used to prevent wet feet... I am used to multi function areas as I am a retired Submariner.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Yeah but still... I don't think I could do it.
So then you would have an extra curtain or something butted right up in front of the shower head? Just seeing the shower head each time I walked by would bother me.
oh yes she did!
Old 05-12-2017, 02:51 PM   #23
Brewerbob's Avatar
Dear Bubblehead,
I ain't hot bunking!!
Yours truly,
Surface Target
Old 05-12-2017, 02:55 PM   #24
Robin97396's Avatar
Bob, by the time they're teenagers it probably won't work. Sadly, most of them learn to swim.
Mysty, when people build their buses right you'd never know there were wheel wells there. That said, I prefer these buses without wheel wells. Fewer build restrictions. Now that I'm towards the end of this build, wheel wells wouldn't really impact the layout very much.
Robin
Nobody's Business
Old 05-12-2017, 02:58 PM   #25
Brewerbob's Avatar
I'm with ^this kid.
If I were by myself maybe. Showerhead still has to be on side wall or the other. Toilet on the other side wall. The drain basin could be from side wall to center. MAYBE.
I'm planning on taking the gf with me. I don't want to be waiting for her to get out of the shower or toilet if I decide I need a glass of milk RIGHT NOW.
Old 05-12-2017, 03:01 PM   #26
Brewerbob's Avatar
How did you live to be this old while being that dumb? Just means you need to use more cinder blocks. They're cheap and reusable even. Remember the environmental 3Rs. Reduce, reuse, recycle.
Old 05-12-2017, 03:04 PM   #27
Ryannmelis's Avatar
Coachwork: Wayne Corp
Originally Posted by Brewerbob View Post
Dear Bubblehead,
Yours truly,
Surface Target
As long as u have your fish (Dolphins) no hot racking required.
1990 International 3800 DT360 and AT545.
2007 Dodge 5.9 with a 6 speed.
6 Kids,1 Cool Ol Lady
Lots of life to live.
Ryannmelis is offline   Reply With Quote
Old 05-12-2017, 03:48 PM   #28
Coachwork: Blue-Bird
Engine: 5.9
For the Rear wheel wells I am considering raising the roof and then raising the floor in the rear of the bus with a step up and storage under. Which includes decking over the aft wheel wheels.
David Moose
Moose is offline   Reply With Quote
Old 05-12-2017, 03:50 PM   #29
Robin97396's Avatar
Dumb luck.
Some of us just have dumb luck. It's like 50/50 you know? I'm definitely on a run at this age. I've been using cinder blocks for the wrong things.
I had some reservations about retroactive abortion because the kids were to strong after they became teenagers. They just weren't cooperative. I must have raised them wrong if they weren't willing to sacrifice themselves for my greater good.
Bodies float eventually when put in water. Here in Oregon we put bodies beneath large stumps way out in the woods. Fertilizer, you know.
Robin
Nobody's Business
Old 05-12-2017, 06:12 PM   #30
Ryannmelis's Avatar
Dear Bubblehead,
Yours truly,
Surface Target
Ok you get the rack in the torpedo room.
Old 05-13-2017, 10:37 AM   #31
My 2c would be to put your storage over the wheels. So you can correct any weight issues to keep the weight in the magic zone on each corner. Not much of an issue on springs but can be an issue with underload air bags.
retiredChemist is offline   Reply With Quote
Old 05-14-2017, 10:49 AM   #32
Brewerbob's Avatar
Had to google that one. Thought everyone got those just by being on board a sub. Would be worth it just so you don't have to hot-bunk.
Just the rear? Will be an interesting look. I think my wells stand about 9" high? I should have held out for a wheelchair bus.
FL has large lizards that take care of bodies. OR has large fish.
As long as there was AC, I would have preferred it. There was more than one snoring ahole in deck division.
I have airbags. Hadn't given that any consideration but then I want to keep all the heavy stuff BETWEEN the frame rails. Tanks anyway. Gotta consider some on board water tho just in case of cold climates.
