Old 11-02-2014, 07:57 PM   #1
Year: 91
Engine: cat 3208 T210
Ignition cut-off problems
After thinking we finally got a handle on all of the interlock cut-off switches, we attempted to take the switches out and re-wire to bypass switches completely. This is where i need help. I have two switches that were on the wall by the side emergency door, one for when the door latch is shut and one for when the barrel bolt slide lock is pushed back in the unlock position. Between these two switches i have a strand of four attached wires coming from the electric panel that i would like to re-wire and bypass the switches completely so I can start the bus anytime. The strand of four wires are white, black, red, and green.
Any help or direction to specific threads would be greatly appreciated!
CostelloCrew
CostelloCrew is offline   Reply With Quote
Old 11-03-2014, 05:34 PM   #2
Re: Ignition cut-off problems
Every bus might be different. If you can post pictures of the switches, and the connections of the colored wires to them, we may be able to remotely help scope out the functions or suggest test procedures to identify the wiring.
It can't be as hard as remotely assisting a doctor in Antarctica perform an emergency biopsy on herself.
Old 11-04-2014, 02:28 PM   #3
Originally Posted by Redbear
If you can post pictures of the switches, and the connections of the colored wires to them, WE may be able to remotely help scope out the functions or suggest test procedures to identify the wiring.
WE says you, I will hold the beer
Old 11-05-2014, 06:19 PM   #4
Year: 91
no worries. after some careful testing (random wire combinations), the switches have been succesfully removed and bypassed! three of the four wires connected with one wire not connected got the bus started. then pulling one of the wires out of the connection turned off the buzzer up front.
Old 11-06-2014, 07:00 AM   #5
Good to hear "no smoke was let out"
Does she run good?
Rear Door Alarm and Ignition cut-off busdriver_phil Conversion Tutorials and How-to's 0 04-20-2010 06:53 AM
Propane Fridge Ignition High Altitude? kirkndopp Heating, Cooling and Appliances 1 09-29-2009 04:49 PM
Chevrolet/GMC ignition retarder/govenor Kirbystud Conversion General Discussions 12 07-26-2009 01:15 PM
Blue Bird Ignition Interlock paul iossi Conversion General Discussions 0 08-20-2007 11:51 PM
electronic ignition lapeer20m Everything Else | General Skoolie Discussions 15 07-17-2006 08:42 AM
