Old 10-15-2006, 08:30 PM   #11
Elliot Naess's Avatar
Engine: 5,9 Cummins
Right, the white wire is probably for the tach. The tach does not work, so...
(Anybody know what redline is supposed to be for a MV404?)
Let's see... It is the #1 cylinder I have trouble with. Oh yes, I have spark there --
ouch! But it seems like I have good spark some times and other times not.
Hard to say. We ran the "kill-one-cylinder-at-the-time" test on the scope and it
showed no RPM drop on #1 each time.
I think we are down to an invisible flaw in the cap as the most likely suspect.
(Or the mouse nest!) I'm going "to town" tomorrow (Sacramento) so I'll get parts
there. Rechecking the vacuum advance, I found that it leaks a little bit, so I'll
replace that too.
I can get a MSD 6A "box" right here in Clearlake for $200,40 out the door.
I suppose that might "cover up for" various other weaknesses that might exist
in a 1981 engine.
Will be gone for a week. Appreciate any ideas you guys might have in the meantime!
Elliot
Old 10-16-2006, 04:43 AM   #12
I'm also a huge fan of the MSD 6A. It's one of those things that shows up more on the "seat of the pants dyno" than anywhere else. My 392 has a petronix aftermarket electronic ignition, seems to work fine.
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 10-20-2006, 07:03 PM   #13
Coachwork: Ward Genesis
Engine: DT466/MT643
Check the compression...I'd bet money #1 will have little or none.
Jarlaxle
Old 10-22-2006, 10:15 PM   #14
Engine: 5,9 Cummins
Quoting myself:
Compression is 120, just like the others.
How much money did I win?
I'm home from a week on the road and I have bought $400 worth of
ignition parts, including a 6A. Stand clear!
Elliot
Old 10-23-2006, 04:56 AM   #15
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Originally Posted by Elliot Naess
. . . and I have bought $400 worth of ignition parts, including a 6A. Stand clear!
I know it will take longer to do it but, if you replace those ignition parts one at a time and check the result, you can determine exactly which component caused the problem, and I, for one, would like to know what the actual fix was.
Griff is offline   Reply With Quote
Old 10-23-2006, 09:57 AM   #16
frank-id's Avatar
Wow all that money for ignition
Do they still make gas engines for buses??? I'm convinced that diesel is the only engine power. I'm gonna get a diesel powered lawn mower. Ahhh yes the smell of diesel on an early autum morning. The work is about to begin... Frank in Idaho.... no smog rules
Old 10-23-2006, 11:42 AM   #17
Steve's Avatar
My only diesel is my mower and yes the smell does make it more enjoyable!
Old 10-23-2006, 12:17 PM   #18
Engine: 5,9 Cummins
The really funny part is spending $400 for ignition parts -- on a $250 bus!
Of course, I spent $2209.40 on tires!
Long term, the tires can go on a newer bus, and the "hot rod" ignition parts
on my street roadster or an other car. I consider this old gasser my
"practice bus", while I keep an eye out for a bargain on a 40 foot Bluebird TC2000
with diesel engine.
Now I need to get out there and work on it -- going on a trip Thursday!
Elliot
Old 10-23-2006, 06:49 PM   #19
eggman's Avatar
$400 for ignition parts on an International Gasser?? Holy cow!! For that, you couldve had fuel injection. Question is, did that take care of your problem?
For some info on IH gassers and on some of the diesels, try http://www.binderbulletin.org
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Old 10-23-2006, 08:38 PM   #20
the_experience03's Avatar
Re: Wow all that money for ignition
Ah..the smell of ether and the words of frustration on a cold morning when your lawn mower's block heater fails to start it.
As for the fuel injection...sure he could have had it, but that doesn't fix a weak spark if that was in fact the problem.
I know it's a long ways away from you, but the guy who does the bus sales at United Truck Body (where I bought mine) in Duluth came into our store a few days ago and said they have some real nice ones coming in. One is a 72 pass. TC2000 with a 5.9, air brakes, MT643 (IIRC), 4.44 ratio, and a host of other goodies. It was always stored in a heated bus barn. No block heater on that one and we're darn near in the tundra up here. Best part was the price...$2700....
You can try their site, but I'm not sure that it has been updated. Either way, don't pay attention to the prices. Mine was listed at $2000 and I paid $1250 without any negotiaion.
http://www.unitedtruckbody.com[/quote]
running both LP and Gasoline in GMC engine captainkf Alternative Fuels | Electric, Propane, Wood Gasification, etc. 4 11-11-2012 07:05 PM
Swap a 7.3 with gasoline engine for parade float?? Elliot Naess International | Navistar Drivetrain 6 03-31-2012 04:13 PM
Looking for a MV404 for my 1981 international bus veralbama Everything Else | General Skoolie Discussions 2 10-11-2008 10:45 AM
International 404, 6.9 and 392 gasoline engines? Elliot Naess Conversion General Discussions 2 02-04-2006 03:48 PM
Convert Ford B700 from gasoline to diesel engine? Elliot Naess Conversion General Discussions 7 11-13-2005 11:23 AM
