Old 04-13-2018, 07:58 PM   #1
lwharma's Avatar
Chassis: Type D chassis manufactured by navistar
Engine: T444e 7.3l V8
In floor heating and space heaters??
Looking for an easy way to heat our bus. We’ll mostly be in 70 or up weather but will spend our first winter in Maryland. We were thinking of installing floor heating. Anyone done this? Also, would an electric space heater be safe? Any info would be awesome? Thanks!
lwharma is offline   Reply With Quote
Old 04-14-2018, 04:21 PM   #2
How's it going with that? Have you gotten it started yet?
Old 04-14-2018, 04:38 PM   #3
roach711's Avatar
Rated Cap: 19
If you'll be plugged in to shore power an electric space heater will be easy and safe. Just make sure the heater has a tip over switch that shuts it off if knocked over.
By "in floor heat" I assume you mean hot water pipes embedded in the floor. That's certainly an option but is way more complicated than a propane RV furnace type heater. The propane furnaces are vented so no worries about condensation and carbon monoxide like there is with catalytic propane heaters.
The Roach Motel
Old 04-15-2018, 04:42 PM   #4
lwharma's Avatar
Not yet. Just trying to plan!
Old 04-15-2018, 05:34 PM   #5
SilentReprieve's Avatar
Chassis: HDX
Engine: 3126 7.2
first off let me be clear, I do not know this ... but what if we used an original type setup with coolant lines in the floor?insulation kind of like radiant heat but had it heated through an external water pump of some style or type... does anyone know if this is available??... kind of like the diesel heaters using air, we use coolant
is this just a dumb question?
Jim
SilentReprieve is offline   Reply With Quote
Old 04-15-2018, 05:41 PM   #6
Rivetboy's Avatar
Jim
It is called hydronic heating search for that term webasto is a maker of the diesel fired water heaters it is complex and exspensive but works very well
Rivetboy is offline   Reply With Quote
Old 04-15-2018, 05:50 PM   #7
Chassis: HDX
Engine: 3126 7.2
phew... lol i thought i was barking up the wrong tree.. lol.. i mean simple enough idea but the design would have to include piping or lines... connectivity to the diesel tank or other tank depending if you want seperate/reserve tank circulatory pump to make it flow and a simple heating element/area but to make it happen is the key oh yeah a thermostat control...lol
Jim
Old 04-15-2018, 05:52 PM   #8
roach711's Avatar
Rated Cap: 19
A few conversions here have done hydronic in floor heat. You need a water heater, some Pex pipe embedded in the floor, a circulater pump and a thermostat/valve to control the temperature.
You get nice warm floors but heat rise is slow in a cold bus. It's more complicated than some other heat methods but very do-able. Probably more suited to full-timers than weekend warriors.
The Roach Motel
Old 04-15-2018, 06:54 PM   #9
Chassis: HDX
Engine: 3126 7.2
hmmm... fruit for thought so to speak... Im a making mine a tiny home... and live in it full time...
Jim
Old 04-15-2018, 07:00 PM   #10
Chassis: HDX
Engine: 3126 7.2
>A few conversions here have done hydronic in floor heat. You need a water heater, some Pex pipe embedded in the floor, a circulater pump and a thermostat/valve to control the temperature.<
So this way is simpler than connecting it to a diesel water heater... I actually like it... my idea so to say was off top of head and random but it literally is same thing as using a bus heater the way they do with engine coolant warming to temps... and a fan... its just radiant or gradual
