Old 09-20-2012, 10:16 AM   #21
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: In the wintertime...
just put a blanket on it put it in ahole and say good nite see u i the spring...just make sure u give it anma befor u put it away...so its pipes don't freez up
keith is offline   Reply With Quote
Old 09-20-2012, 06:15 PM   #22
lornaschinske's Avatar
Rated Cap: 89
Originally Posted by GreyEagle
Originally Posted by crazycal
Sure I would. It gets down to 50* sometimes and I always have something to say.
This is true, ........ When I picked him up to go get his bus he never shut up!!!
And the door he was sitting next to didn't accidentally open as you rounded an outside corner?
Hey, I know a real good road for that! It's the road I learned to drive on... The section between Franklin & Highlands as you are going thru the Cullasaja Gorge (on the map listed as "Whitelightening Heights" in reality its Wildcat Cliffs either way you are looking at an 80° to 90° incline mountain side that is mostly rock & trees). I've seen more than on vehicle door come open while going around a corner in that stretch. Always made me wonder..... Of course you can't put a big RV/Bus/Truck up that road. You would get a big fine and the cost of the tow truck is high enough that it discourages most folks from ever attempting it again.
On edit: there's a nice little no hookups campground (Van Hook Glade) which is the last place you can put an RV up on the Franklin side (we tent camped there). A little trail connects the campground to Cliffside Lake. Nice picnic area and good swimming at the lake. at the Lake. The Lake is not real crowded except for holiday weekends. I believe it's pit toilets at the campground but the Lake has a bathhouse with flush toilets and cold showers. DON"T TAKE A SHOWER THERE! The water comes from the lake and it runs about 35°to 40°F during the hottest part of the summer. It's like being hit in the head with a sledge hammer, not that I know what being hit in the head with a sledge hammer feels like. But it must hurt almost as bad as running into the damned padded rail over the rear emergency door on the bus. Lots of folks fly fish in the river across the hwy from the campground. If you have a license and like to actually catch fish to eat, you can use whole kernel corn on a hook to catch rainbow & brown trout out of the river or pan fish out of Cliffside lake (lots of fish there).
Fulltime since 2006
Old 09-20-2012, 06:42 PM   #23
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Hi.
I'm hungry!
You Gotta Let Me Fly
Old 09-20-2012, 06:52 PM   #24
Rated Cap: 89
Here's what I originally posted on Escapees (and removed). So it was aimed at them. But I thought it might contain helpful info (links) for some here. Just to get your imagination going. It's really just how to build old-fashioned storm windows when you strip it down to the basics. I've noticed that the S&S bunch tend to be very limited on imagination. I found the "real world" temp reading on the bubble wrap windows very interesting. I dislike living in a dark cave all winter. I also now want one of those thermometers... So here it is, pick it apart as that seems to be all some of you are interested in.
FRUGAL ALERT! DIY "Dual Pane" Windows
For the FRUGAL folks only!
This is for frugal folks that like DIY stuff that saves them money. So I really don't care who you can buy brand new thermal triple glazed windows filled with the latest exotic gas that will add an R-Value of .001 to the standard R-Value of less than R-2. This is not whom this post is intended for. This post is MY OPINION.
There is a topic going on another thread about dual pane windows. Winter is rapidly approaching and not all of us who live 24/7 in our Residential Vehicles can leave cooler climates for warmer ones due to things like working. I thought a little info on DIY Dual pane or storm windows might be helpful to those of us who have older RV's that do not have the dual pane windows (or do have dual panes with out thermal breaks in the metal frame)
Dual pane windows are simply permanent "storm windows". I'm sure most on here are old enough to remember old-fashioned winter storm windows. If your RV does not have dual pane, it is a simple and fairly easy, low cost DIY fix (possibly a more efficient fix than replacing with metal framed dual panes without a thermal break). The "low-e" film is also available as an aftermarket fix (look on Amazon --- http://www.amazon.com/Gila-LES361-Contr ... indow+film --- or any place that sells the aftermarket window films). No need to replace all your existing windows unless you have a burning desire to spend your money. If you have a burning desire to spend your money then you are not frugal and should stop reading this.
First off, you need to understand what insulated glass is --- http://www.wisegeek.com/what-is-insulated-glass.htm --- . Once you understand the basic principal and importance of a thermal break -- http://www.wisegeek.com/what-is-a-thermal-break.htm -- you can easily understand why adding a "storm window" to the interior (or exterior) of your RV is so easy and very helpful in keeping your RV warmer in the winter. Using Acrylic "glass" from home improvement stores, you can custom build storm window panels to fit every window in your RV. I would bet that you could do this for less than the cost of a single dual pane window unit. I think dual pane window units are over priced. They are not that great. Basically you are making an R3 hole in an R11 wall. If your metal framed window does not have a thermal break, then you are looking at a negative R value! Lots of info all over the internet on making storm windows. I'm fond of the Mother Earth News website --- http://www.motherearthnews.com/ ---. It's handy to use their website's search engine to look up old magazine articles and the read the articles off the CD's I have of their back issues. Even the plastic "shrink with a hair dryer" storm windows will work great to reduce the amount of heat loss from your "high quality" RV windows. Using the acrylic plastic glazing in conjunction with a low-e film (from Amazon--- http://www.amazon.com/Gila-LES361-Contr ... indow+film --- or home improvement stores) will add yet another layer of R-value (put it on your glass windows not the acrylic to reap benefits during the summer too).
DIY storm windows will allow you to cover the metal frame and create a thermal break, preventing the "heat sink" effect (ever notice that your metal frames around the windows ice up?) Even if you do have dual frames and your metal frames ice up in the winter, you still would be $$ ahead to make a storm window to cover the whole window including the metal frame. The "dead air space" is a terrific insulator. In the summer, you can remove the dual plane (to open your windows) and store the flat panels behind your couch or behind your clothes in your closet.
I see many RV's in campgrounds with Reflectix heat barrier (it's NOT insulation it's basically R-1 with a reflective heat barrier and only "R-14" under specific install) covering all their windows. While that's not so bad during sunny summer time, once the overcast days of winter set in, it's like living in a cave. Using regular clear bubble wrap, like used for packing material, can be used on windows and it still allows light in. A huge plus during the winter. Based on temp readings, you can go from R1 on single glazed window to the equivalent of a dual pane window - R2 in just a few minutes for just a few bucks.
--- http://www.builditsolar.com/Projects/Co ... lewrap.htm ---
--- http://www.builditsolar.com/Projects/Co ... ctions.htm --- another bubblewrap install using "greenhouse" bubblewrap.
A Cardboard shutter that was made by the same folks who did the bubble wrap windows. --- http://www.builditsolar.com/Projects/Co ... hutter.htm --- Perhaps made from some rigid inulation for more R-Value?
--- http://www.builditsolar.com/Projects/Co ... Treatments --- Builditsolar's Home Energy Conservation Projects website. So much good info. Some you can use, others not.
As self converters, we had the opportunity to be able to make choices in much of our energy requirements that those that live in manufactured RV's do not (like how much insulation to use, using more energy efficient residential products, etc). There is still a lot of changes you can make to a sticks-&-staples RV to make it more liveable in cold weather as well as more energy efficient. It just takes a little knowledge (available via the internet) and the willingness to think outside the box. Insulating your windows (and their metal frames) is a simple thing to do and can save you much $$ this winter.
FYI: Clear bubble wrap on glass with a clear sheet of plexi over that on the interior side. I still need to do the huge front windshield. I frosted my glass windows on the sides for privacy. You can't see in/out so the bubble wrap makes no impact on the view or the RV's on each side of us...
Fulltime since 2006
Old 09-23-2012, 11:10 AM   #25
Stuff's Avatar
I wrapped the water hose with 4" insulated duct wrap. have a heat tape on that to that is a self regulating kind, no button bs.
sewer has the self regulating along the bottom of the lines. didnt insulate them and the skirted bottom of the trailer keeps the wind chill off.
Old 09-24-2012, 04:27 PM   #26
kimberlink's Avatar
Engine: DT466 / AT545
Rated Cap: 71
Lorna, I as a newcomer want to thank you for your posts this info does make me think about things I should incorporate while building mine. I look to all of you for your expertise, trials and errors. You all have been a great help Please dont stop posting whatever is on your mind it does help.
Now If I could figure out how to post pictures as I build mine
The most terrifying words in the English language are: I'm from the government and I'm here to help.
Ronald Reagan
https://s1253.beta.photobucket.com/us...k1961/library/
kimberlink is offline   Reply With Quote
Old 09-24-2012, 05:11 PM   #27
Rated Cap: 89
Originally Posted by kimberlink
... Now If I could figure out how to post pictures as I build mine
photobucket!
Get a free photobucket account. Upload any photo that is ready for viewing (or all your photos) there in an album. Don't move your images around.
Click on a photo to go to it's page. On the right hand side is a section where you can click to copy either full size image or thumbnail image.
You can have sub albums of your main album. That's a good way to keep things organized. There is a "how to post pics somewhere here plus it's been discussed several times.
Fulltime since 2006
Old 09-24-2012, 05:36 PM   #28
kimberlink's Avatar
Rated Cap: 71
Thank You Lorna here is the link to my photoBucket
http://s1253.beta.photobucket.com/us...k1961/library/
Ronald Reagan
Old 09-24-2012, 06:42 PM   #29
That parts done,so now move mouse over picture...see menu that drops down?
Left click on bottom link "IMG" andit will copy it,then just paste it into your post....sorry for hyjack
Old 09-24-2012, 08:11 PM   #30
Rated Cap: 89
Pick a photo to look at. On right side of page under "LINKS" left click image code (in this case " IMG thumb" and "paste" (Ctrl v) here
So simple once it's explained isn't it. Photobucket makes it easier than uploading from your computer or a personal website.
Fulltime since 2006
Old 09-26-2012, 12:40 PM   #31
kimberlink's Avatar
Rated Cap: 71
Some new photos of the conversion.
Ronald Reagan
Old 09-26-2012, 09:26 PM   #32
Nice fabrication. I love to watch others work. Keep the pics comming
Old 10-06-2012, 09:51 PM   #33
jkronmiller's Avatar
Chassis: IH
Engine: 444E
I would be highly interested in the dual pane window info. We are new to this and are working on converting a 98 IH and Carpenter body. Due to some health issues I'm. Told I have about 3 years to enjoy it. So any info that will help is much appreciated mam.
jkronmiller is offline   Reply With Quote
Old 10-11-2012, 11:29 PM   #34
Chassis: IH
Engine: 444E
Lorna- Thanks for the frugal window info! That is the kind of info I for one need badly. Thanks for posting it!
Old 03-27-2015, 09:57 PM   #35
jenna1969's Avatar
Ok so speaking of full time and Winter living, and since I live in the Northeast, do campgrounds in the rest of the country allow you to stay in your "home" from Nov.1st - March?? Up here they have seasonal and allow you access for maintainance but will they let you stay in your bus?? One campground told us that we could stay but water would be shut off and depending how weather holds up for access...still looking around...I guess not too many people do this full time!
jenna1969 is offline   Reply With Quote
Old 03-29-2015, 08:33 AM   #36
It depends a great deal on location and profitably of the park. Here in Colorado there are lots of year round parks that deal with cold and snow because lots of us enjoy skiing and other mild winter activities. In North Dakota there are also several because the demands of the oil field create the need for year round RV solutions. You'll likely find very similar results elsewhere.
drifted_cowboy is offline   Reply With Quote
Old 03-29-2015, 03:16 PM   #37
Lorna this is great info, and it does work. Whether it is a temp fix before you can get 'the real thing', or a way to save on your energy costs, or a fix to a rental property- it really works well!
I have been using bubble wrap for years in drafty rental houses and apartments. The house I currently live in is very poorly insulated, and has original double hung windows with wall weights from pre-1940. Some have storms. Some don't. I got a giant roll (30"? Wide) and double-wrapped all my windows. It made a 10*F improvement with the same settings and outside temp. I label and re-use my wrap from year to year.
This year, facing weeks of below 0*F, and once getting to -31*F, I added 'curtains' of plain old fleece from a fabric store that I picked up for $3/yd which was 5' wide. These windows are warmer to the touch than the solid walls now. Gotta love thermal breaks! I keep the curtains down on my Northern/shaded windows, and open the sunny-side curtains to let in the light.
If there is a storm window, I put one sheet of bubble wrap in between the storm and the interior glass, with the bubble surface to outside glass to make more air barriers- including the one between the flat side and the inside glass. Then I make a sheet big enough to cover the entire window frame (using clear packing tape) and attach it with whatever method works best for that window. I've used tacks, painters tape, removable tabs (command-style), tension rods, magnets, etc. my windows went from ice covered and able to blow a candle flame, to no draft with no frost on the inside overnight.
I've also made indoor 'door curtains' for doors I don't usually use in winter, and wrapped my storm doors with bubble wrap too.(with a window flap if necessary )
I've also used a layer or two on outside walls under cabinets with susceptible plumbing. My cheap $1 thermometer registered a 20* difference in one cabinet this year when I double lined the base and up the sides and back. Those pipes didn't freeze up this year! Yay!
~Pamela
SassyLass is offline   Reply With Quote
