Old 04-02-2008, 12:17 PM   #1
Re: Injector Pump Leak
Hey I got the same bus. Bosch makes it. I just had mine rebuilt. And takin it in and out twice. Where's it leaking out of?
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Old 04-02-2008, 04:55 PM   #2
Elliot Naess's Avatar
Engine: 5,9 Cummins
Start by deciding if you have a rotary or an inline pump. You'll know by just looking at it.
Could it be your return fuel hose? On inline pumps, the return hose is VERY suceptible to cracking from all the heat in that area.
Old 04-02-2008, 11:56 PM   #3
Engine: 5,9 Cummins
That's a rotary pump. Those were also used on Dodge pickups up to around 1994, so you might want to take a look at the Dodge Cummins Diesel forum. Tons of information about all years of the Cummins 5.9 there. http://www.cumminsforum.com/forum/
Old 04-03-2008, 07:12 PM   #4
I've taken that pump off of that motor 2 times now. What a B*tch! It's not as hard on the reg dodge motors because there's no air compressor. On school buses there is. They make a two special tools for the job. A Curved 13mm wrench to reach around to the bottom nut/stud holding it to the front cover. Second is an engine barring tool. It allows you to turn the motor with a socket wrench. It's tedious and a pain but doable. As far as replacing the gasket, you need to call a pump place. These things are timed to the motor so any mis adjustment of it's cycle will throw it off. It's a pain. Oh yeah take a cushion or something and put it on the motor when your dinking around. Never had to many bruises on my chest before. Good luck
Old 04-06-2008, 10:22 PM   #5
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
that pump thing looks expensive....... yikes
Old 04-08-2008, 08:30 AM   #6
sportyrick's Avatar
Chassis: F33695
might be a seal instead of a gasket, might have a professional look at it. sportyrick
Old 04-08-2008, 08:30 AM   #7
sportyrick's Avatar
Chassis: F33695
Old 04-08-2008, 01:43 PM   #8
Engine: 5,9 Cummins
He also said I should not attempt to do this myself.
From what little I have learned over the years, I'm inclined to agree.
Old 04-08-2008, 08:24 PM   #9
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
pay the 350 save the greif if it messes up again they will fix it under their warranty....do they have one?
Old 04-09-2008, 09:54 AM   #10
Ask your local pump guy if you can borrow the curved wench and engine barring tool. It will save you some frustration!
Old 04-09-2008, 10:13 AM   #11
Engine: 5,9 Cummins
Few men are willing to lend out a well curved wench -- unless the marriage is already beyond repair and he is looking for an excuse to file for divorce.
Injector removal and Install E-350 van 7.3 diesel motorcyclemarty Short-Bus Conversion Projects 6 06-28-2022 10:05 PM
Air Leak Jive Turkey Mechanical and Drivetrains 1 03-27-2011 07:14 AM
injector rebuild adamanderr Conversion General Discussions 4 01-16-2008 08:21 PM
Looking for an injector rebuilder shop. frank-id Everything Else | General Skoolie Discussions 1 08-15-2006 11:17 AM
6.6/7.8 injector pumps the_experience03 Everything Else | General Skoolie Discussions 1 03-10-2006 01:52 AM
