Old 01-14-2008, 06:33 PM   #1
injector rebuild
i think my injectors are bad and would like to learn how to rebuild them as they are so expensive and i have eight. has anyone experience with this or can tell me where to start looking. and or where does one find rebuild parts.
thanks
adam
adamanderr is offline   Reply With Quote
Old 01-14-2008, 07:24 PM   #2
Year: 1987
Engine: DD 671
Rated Cap: 73
Re: injector rebuild
While I know nothing about injector rebuilding, a little more information might help someone that does, what type of engine do you have?
sauce is offline   Reply With Quote
Old 01-15-2008, 03:36 PM   #3
international 9 liter. i've heard it has "pencil injectors".
Old 01-15-2008, 08:06 PM   #4
bus-bro's Avatar
Engine: 3208 na boat anchor
Generally, one unit exchanges injectors, usually not to expensive. Rebuilding requires a clean area, proper tools, and tech. info. Shouldn't be too hard to do--though easier to exchange.
Old 01-16-2008, 08:21 PM   #5
GoneCamping's Avatar
I work for a heavy truck dealer, and to the best of my knowledge the parts for rebuilding injectors are not readily available. This is an area where the manufacturer holds the keys and likes to keep it that way, as they make huge $$ off of selling replacement injectors. That being said, you might be able to find parts somewhere, but I don't have a clue where you would go for them. We don't rebuild them, and we are dealer for Cat, Cummins & Detroit, all we do is replace them, and beware they generally have a very high core charge, so make sure you have the dirty core with you when you go to buy one.
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Cost of engine rebuild and tranny rebuild? dgorila1 Mechanical and Drivetrains 2 08-07-2011 11:45 PM
Injector removal and Install E-350 van 7.3 diesel motorcyclemarty Short-Bus Conversion Projects 5 07-17-2008 02:35 PM
Injector Pump Leak dlor1 Conversion General Discussions 10 04-09-2008 10:13 AM
Looking for an injector rebuilder shop. frank-id Everything Else | General Skoolie Discussions 1 08-15-2006 11:17 AM
6.6/7.8 injector pumps the_experience03 Everything Else | General Skoolie Discussions 1 03-10-2006 01:52 AM
