Old 06-02-2010, 02:16 PM   #1
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Input on inverters.
OK, here it goes. I have a few questions about inverters that I have.
1. I bought a HUGE pure sine-wave inverter from a truck dismantler a couple of years ago. It weighs a lot. Output is 3000 or 3500 watts. It says 33 amps at 120 volts. Serious stuff. It came out of a power utility truck. How many batteries would I need to have to feed this monster? I imagine they had a second alternator to power this thing. Does the juice this thing draws from the batteries go up as the demand goes up or is it all or nothing. I'm thinking it would be nice to use this for the AC if I put one in the bus.
2. I have a number of smaller inverters as well. I have a 300 watt pure sine-wave, a 1000 and 1500 watt (not sine-wave) and the UPS's that I spoke about in the other thread.
Should I use multiple inverters to split things up. Maybe have one smaller one on all the time hooked up to the chest fridge and have the others on switches and turn them on as needed?
I'm hungry!
You Gotta Let Me Fly
Old 06-02-2010, 11:12 PM   #2
Moderator
crazycal's Avatar
Re: Input on inverters.
Should this be in a different section?
I'm hungry!
Old 06-03-2010, 10:18 AM   #3
Steve's Avatar
Yes you did not write a tutorial, you asked a question.
Old 06-03-2010, 10:25 AM   #4
Moderator
crazycal's Avatar
Thanks for moving it.
I'm hungry!
Old 06-04-2010, 09:48 AM   #5
Moderator
crazycal's Avatar
I thought that if the fridge was the only thing running, I would have one small inverter running and the others switched off. If the big one doesn't use a ton of juice on standby, I can use that one.
I'm hungry!
Old 06-04-2010, 09:56 AM   #6
Moderator
crazycal's Avatar
I am going to use that chest freezer conversion that Smitty did. I think he said his used 250 watts that whole day. I want to avoid using a generator. Unless it's a Honda EU, they use too much fuel. I want to use PV solar and batteries for as much as I can.
If you want to find out how to size what you need, get a Kill-a- watt. That will tell how much power everything uses.
I'm hungry!
Old 06-04-2010, 07:09 PM   #7
Moderator
crazycal's Avatar
You come with some great stuff. Thanks for the link.
I'm hungry!
use of inverters putterspitt Electrical, Charging and Solar 4 11-25-2010 09:06 PM
Inverters.......ugh opus Electrical, Charging and Solar 6 10-31-2010 04:23 PM
Power inverters and their uses drchefscott Skoolie Conversion Projects 17 04-16-2009 08:46 AM
inverters dwheward Classifieds | Buy, Sell, Swap 2 07-20-2008 04:55 PM
cheap power inverters batchlor BusMan Everything Else | General Skoolie Discussions 2 04-06-2004 05:02 PM
