Old 06-12-2010, 09:52 PM   #1
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: Installing a propane cooktop
Yes, you can get hoses that accept the 1 lb disposable bottles. You may need to get a regulator for that stove no matter which way you go though. If so, there are hoses and/or adapters that connect the regulator to the 1 lb bottles.
Old 06-12-2010, 10:13 PM   #2
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
You should be able to find all the hoses you need in rubber. Just make sure it is designed for propane and you will be fine. Best place to find the hoses is a propane dealer, if they don't have it they can usually make it for you.
Old 06-14-2010, 12:08 AM   #3
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Ace Hardware down the road from me carries those hoses. Shortest one is 5', longest 12'. Home Depot carries them too, but I've only ever seen the 12 footers there.
td
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 06-14-2010, 10:42 PM   #4
wtd
wtd's Avatar
Year: 1982
Another thought - you'll actually need two hoses, since the stove needs a regulator. One from the 1# bottle to the regulator and one from the regulator to the stove.
About the camp stove falling - I drilled a hole on each side of the sheet metal shell and put a coupla long thin screws through the stove into the countertop.
Where DIY meets WTF
Old 06-14-2010, 10:45 PM   #5
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
Originally Posted by wtd
Another thought - you'll actually need two hoses, since the stove needs a regulator. One from the 1# bottle to the regulator and one from the regulator to the stove....
You can get hoses with the regulator already attached. But like I said, just go into a propane shop and they should be able to hook you up (pardon the pun).
Wedgewood 17' cooktop & oven --Georgia **SOLD** The-Breeze Classifieds | Buy, Sell, Swap 1 07-14-2014 12:13 AM
Installing RV Windoew Stu & Filo. T Conversion General Discussions 1 12-07-2013 09:31 PM
Vent for Range/Cooktop lornaschinske Heating, Cooling and Appliances 18 10-02-2012 08:39 PM
installing awnings gbstewart Conversion General Discussions 9 05-18-2012 01:52 PM
Buying/Installing a Dual Fuel Propane Kit? Nathan Conversion General Discussions 4 02-25-2008 12:46 PM
