Old 12-07-2013, 09:09 PM   #1
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Installing RV Windoew
Hello all, I'm converting a 88 Crown & I'm taking all the passenger windows out & installing RV windows, my plan is to have 1"by 1.5" tubing bent for the frames then welding them in between the ribs where they will be placed. Just wondering how others have done this install?
Old 12-07-2013, 09:31 PM   #2
wmkbailey's Avatar
Engine: 3126
Re: Installing RV Windoew
Maybe I have this wrong, but when I did my van, I didn't put any framing around the window. The RV windows I used and have for my bus have a clamp ring. I have the steel skin on the outside, then insulation and 1/4" plywood on the inside. Cut the hole, put butyl tape around the window ring and place it in the hole. Then screw the inner ring to the window and it clamps tight. My van use 1 1/2 windows, I have 3" for the bus.
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
installing awnings gbstewart Conversion General Discussions 9 05-18-2012 01:52 PM
Installing A Fridge lornaschinske Heating, Cooling and Appliances 3 05-16-2011 06:41 PM
Re-installing windows in Bluebird ron_erickson Conversion Tutorials and How-to's 5 05-09-2011 01:27 PM
iNSTALLING A 13,500 BTU TOMMORROW putterspitt Conversion General Discussions 8 08-13-2010 08:44 AM
installing a generator.. colliervilledave Conversion General Discussions 4 03-01-2009 09:14 PM
