Old 06-15-2010, 01:01 PM   #1
Steve's Avatar
Re: Installing Tanks without Welding
All of my water tanks are inside the bus, this also helps against freezing if I am using the bus in the winter. If you want to put them under the bus you can use some straps around them that you bolt to the frame.
Old 06-15-2010, 01:54 PM   #2
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
I am planning on mounting my freshwater tank inside the bus under a bench or couch, or wherever seems convenient with my final layout. The wastewater tank(s) are going under the bus to avoid drainage problems, plus it is easier to mount the toilet directly over the blackwater tank and let gravity do its thing. I have seen installs using angle iron and threaded rods. I can't remember whose install it was, but hopefully someone remembers and can point us in the right direction.
Old 06-15-2010, 04:06 PM   #3
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
I think it was Jake von Slatt's skoolie. I think he has photos in the gallery, but if you can't find it there, google Jake von Slatt. He also did a nice youtube video.
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: https://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Welding? Zephod_beeblebrox2 Conversion General Discussions 15 02-01-2015 09:39 AM
Safe Arc Welding on A Bus jeff Mechanical and Drivetrains 2 07-10-2012 02:27 AM
So, about that welding near the gas tank... Ob1 Conversion General Discussions 1 05-06-2011 02:58 PM
Welding Advice Hvbuzz Conversion General Discussions 2 12-02-2010 01:53 AM
Welding to Frame Rails? The Slims Conversion General Discussions 15 12-12-2006 09:38 AM
