Old 09-20-2016, 10:50 PM   #21
Tootalltechie's Avatar
Year: 1974
Coachwork: Blue bird
Chassis: CHEVROLET C60
Engine: 350 ci on propane
Rated Cap: 48
I checked out 4 dogwood stoves, very nice. Cost to ship to me is $$$ (converting Canadian dollars to United States makes it even worse)
I found this company relatively close.
http://www.canvastentshop.ca/index.php
Tootalltechie is offline   Reply With Quote
Old 09-20-2016, 11:39 PM   #22
NowhereFast's Avatar
Chassis: Carpenter
Engine: d466 mechanical
Wood stoves look cool in a bus! But, I have absolutely no idea how to tend a fire. I've only seen snow 3 or 4 times.
Nowhere Fast - Sarasota, Florida
NowhereFast is offline   Reply With Quote
Old 09-21-2016, 12:15 AM   #23
When you're cold.....
You learn fast!
Old 09-27-2016, 04:43 AM   #24
Year: 1974
Rated Cap: 48
I have been reading about wood stoves. Tent stoves are no a good thing permanently installed when it comes to insurance. just a heads up
Gordon
Old 09-27-2016, 08:10 AM   #25
If bolting a steel stove to the floor should I still pour cement? This is something I'd rather be safer than sorry with but the cement is a hood chunk of weight
EricW is online now   Reply With Quote
Old 09-27-2016, 10:21 AM   #26
Rated Cap: Your mom
You don't need to pour cement for the hearth. You can use fire rated cement board and air gaps. Much lighter...
Old 09-27-2016, 10:26 AM   #27
And...never use conventional Portland for any situation where the heat may get above about 200 degrees. Fireplaces, chimneys and such require the use of special "refractory" cement which is rated to 2000 degrees to handle the heat. Regular Portland will crack apart and even sometimes explode.
Old 09-27-2016, 10:40 AM   #28
If I have an air gap and fire rated cement board under a 200lb wood stove that I bolt tight to the floor I'm thinking the board would crack? I will only do air gaps on the walls. The floor is the spot in qiestion. Can I bolt the wood stove to the floor without that stuff cracking out? I will have 2ft by 2.5 in angle iron that it sits on. Will that displace the weight enough to avoid wearing that fire rated cement board?
Old 09-27-2016, 10:46 AM   #29
Fire rated cement board should be fine as long as the weight of the legs doesn't punch through from bouncing around. Since most wood stoves have a fairly small footprint, placing or even welding pads under the bottoms of the feet to spread out the load might be a good idea. Just a thought.
Old 09-27-2016, 11:07 AM   #30
Rated Cap: Your mom
Yep, cement board should be fine as long as you distribute the weight enough. Luckily my stove has a pedestal under it so it will get bolted straight through our granite slab hearthstone and floor without worries about weight distribution... I'm installing it this week so I'll try to get some pics of the hearth/heat-shield/flue and all that good stuff.
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
