Old 04-04-2017, 06:59 PM   #1
eyebrowski's Avatar
Insulate underside of bus floor?
I have a 6'-1" ceiling and am trying to preserve all the height I can. I'm thinking a closed cell foam spray but am worried about trapping moisture. Thoughts? Has anyone done this?
eyebrowski is offline   Reply With Quote
Old 04-04-2017, 07:19 PM   #2
Robin97396's Avatar
My foam guy said the closed cell foam doesn't pick up water.
I also wanted to foam under the floor but it's pretty complicated getting full coverage on a bus with all the things already mounted underneath. I'm going with rigid insulation under plywood like a floating floor because it's a lot cheaper and coverage is more complete.
The spray guy didn't want to do my floor from underneath. He'd be even more covered by falling particals from the foam.
Robin
Nobody's Business
Old 04-04-2017, 07:23 PM   #3
turf's Avatar
my bus has the spray foam underneath. it came that way from the factory. its a '93 - so 24 years and it still holding strong underneath.
Turfmobile Build Thread
Old 04-04-2017, 07:32 PM   #4
Chassis: Blue Bird
Engine: ISC 8.3
Here's a view of the foam under the floor on my bus:
I believe it's a factory-installed option because there isn't any mess on the wiring harness, hoses, etc. Looks to have been installed before those things were.
The rough appearance doesn't look like conventional spray application. It looks more like somebody had a hundred cans of Great Stuff and squirted a thousand little blobs side by side until the whole floor was covered.
Not that I think this is The One True Way; it's just a reference point of how a presumed factory-installed job was done.
Old 04-04-2017, 07:36 PM   #5
BurlKing's Avatar
Year: 92
Engine: DTA360 5.9L
So odd! I have always thought spray foam on the underside of a bus is just plain crazy and stupid. Apparently not...
I guess im wrong, 24 years and thats held up like that? Not bad at all!
Sent from my LGLS775 using Tapatalk
BurlKing is offline   Reply With Quote
Old 04-04-2017, 07:41 PM   #6
Robin97396's Avatar
I've seen other photos of under floor spray insulation and it looked more like 6"x6" pillows stuffed up tight side by side. The professional spray foam is much tougher than foam in a can. I had to use a saw to cut it most of the time, like a soft wood.
Robin
Nobody's Business
Old 04-04-2017, 07:42 PM   #7
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
Since the "mechanical" under the bus needs to be serviced. It would be very difficult to do any service if everything was installed before sprayed. On some rvs' people have enclosed the frame and mechanical in a rigid foam & plywood boxes but that is a lot of work.
Tootalltechie is offline   Reply With Quote
Old 04-04-2017, 08:16 PM   #8
Robin97396's Avatar
I guess that would keep your tanks from freezing. Even propane froze in Alaska winters.
Robin
Nobody's Business
Old 04-05-2017, 07:04 AM   #9
tobeamiss's Avatar
Now that's good for thought!!
oh yes she did!
http://www.skoolie.net/forums/f11/to...-it-16557.html
Old 04-05-2017, 08:30 AM   #10
Year: 1974
Rated Cap: 48
Propane stops vaporizing near -40 F. I'm not sure if it stops flowing in liquid form at that or lower.
Up here in northern BC I insulate & enclose the crawl space under my mobile home and also insulate pipes wrapped with electrical heat tape.
