Old 09-19-2006, 10:14 AM   #1
Year: 1973
Engine: 392 gas International
I did almost the same thing with mine. Spent one winter with temps going down to 20 below. Only problem was the floor. Skirting and insulation will help that.
It don't make no sense that common sense don't make no sense no more. - John Prine
Hawkcreek is offline   Reply With Quote
Old 09-19-2006, 08:46 PM   #2
oldog12's Avatar
Try and get some hay bales and put them around the skirt of your bus to cut down on air movement underneath your bus; otherwise when the wind howls, you're loosing heat all around.
oldog12 is offline   Reply With Quote
Old 10-01-2006, 02:20 PM   #3
TomCat's Avatar
Year: 1987
Chassis: SaftLiner
Engine: Cat 3208 Turbo 250HP
If you're going to skirt your bus with a natural material, use straw, not hay. Hay contains all sorts of stuff that rodents will find inviting.
Jay
http://jsbird69.zoto.com/user/lightb...aded-desc/0-90
Jay
87 SaftLiner
TomCat is offline   Reply With Quote
New to this - Structural, Heating and Insulating Questions Ilexis Heating, Cooling and Appliances 5 10-15-2014 06:01 AM
Insulating question wmkbailey Conversion General Discussions 13 01-22-2014 06:24 PM
DIY Insulating Window Quilts lornaschinske Everything Else | General Skoolie Discussions 8 08-13-2012 08:58 PM
insulating hood? gbstewart Conversion General Discussions 6 09-24-2010 10:07 AM
Why are some of you insulating your bus? crazycal Conversion General Discussions 11 03-24-2007 10:50 AM
