Old 02-16-2004, 06:42 AM   #11
Vern1's Avatar
Greetings,
I removed all the sliding windows as they were noisy as all get out.
They rattled and squeeked a lot after 25 years on Texas back roads!
I framed in the areas for the RV windows I removed from the 5th wheel with 1 1/2" square tubing held flush with the outside for a good skin fit.
I then skinned over the oustide with .050 aluminum.
I removed all the skin from the inside walls except the bottom impact strip.
The walls were a little over 1 1/2" thick, so I stuffed two pieces of 3/4" sheet foam into the spaces. The frame work of the bus was a z channel, so it resulted in a nice tight fit. If there was any air space where I had a "senior moment" and did a bad cut, I filled the area with spray foam.
For the ceiling, my bus has two pieces of sheet metal running from front to back. The middle section of the roof about 3 feet wide was insulated with fiberglass bat insulation. I discovered this while installing the AC and vent holes. There was no other insulation in the bus at all! Since the bottom edge of the sheet metal on the inside was already loose after I removed the window trim above the windows, I only had to drill out one row of rivets to allow me to pull the roof sheet metal down slightly. This was just enough to allow me to slide in two sheets of 3/4" foam into the roof between the outside skin and the inside skin I had pulled down. I then filled any air gaps with spray foam. This process on the roof alone took me about 2 days and cost many skinned and bloody knuckles!! My hands hurt just thinking about that ordeal.
Looking back as I sat in the bus yesterday morning while it was near freezing outside and I am comfortable inside with only a 750 watt heater keeping the inside warm, IT WAS WORTH IT!! With the insulation and a still bare floor, it is much nicer inside and so much quieter going down the road. I can only imagine how much better (quieter and better temp control) it will be when I get the foam and carpet on the floor.
Hope this helps or adds food for thought......
Cheers,
Vern1
1976 International Wayne - ON THE ROAD!!
http://www.pettypb.com/bus
Vern1 is offline   Reply With Quote
Old 02-16-2004, 07:56 AM   #12
Father_of_10's Avatar
Thank you for the information. I think I will follow your advice and remove the metal on the walls, but I am not sure about the celing, Ouch!
I will be picking up our bus in the next few weeks so I have some time to dream before I wake up and have to start working.
Have a great day
Father_of_10 is offline   Reply With Quote
Old 02-16-2004, 10:48 AM   #13
Vern1's Avatar
Greetings,
On the ceiling, it wasn't completely removed.
The center 3' or so was already insulated with fiberglass bat insulation.
Counting the curve down on each side, this left about 4' on each side.
Since the edge was already loose above the windows, I only removed the next row of rivets which allowed me to pull ONLY THE EDGE down enough to stuff the sheet foam in place.
I found that if I cut the foam to the width required to fit between the metal frames that I could lay it down with a 1' block under each end and put some weight in the middle (a couple of cinder blocks) and let it set for a couple of hours, it would gently take a bow which made it so much easier to put in as it was "pre-curved".
That little discovery saved more than a few "blue words"......
Cheers,
Vern1
Old 02-16-2004, 09:28 PM   #14
lapeer20m's Avatar
my windows also rattled quite a bit when i first brought home bus. Since i planned to cover most of them with insulation on the inside, i used a calk gun and sealed all of the windows that were to be covered. This kept them from rattling, and added extra protection against air leaks.
Old 02-16-2004, 09:29 PM   #15
lapeer20m's Avatar
Old 02-17-2004, 06:17 AM   #16
Vern1's Avatar
Greetings,
Caulking the windows that will be covered or not opened is a good idea!
When I was doing the windows and skin on mine, I would start it up and turn it around to take advantage of the shade.
During these "turn around" maneuvers, I noticed the sheet metal that I had added would reverberate and made LOTS of noise.
I remembered doing body repair on various vehicles and would sometimes find caulk where the parts lapped or were close - look under the hood of most autos where the skin attaches to the frame for a good example - so I ran a short bead of caulk where the skin was attached to a frame member.
This made so much difference on vibration induced "reverberation" that I did the same thing to the existing skin under and above the window openings.
Believe it or not, this cut down a bunch of noise.
Cheers,
Vern1
Old 02-23-2004, 10:43 PM   #17
Originally Posted by Tullamore
For the ceiling just drill holes every couple inches and spay in expanding foam.
Neat idea, hadn't thought of that. I found fiberglass up there already, but presumably I could do this. Any idea how much foam it would take?
I was thinking of going rigid board with parallel knife cuts to follow the curve, but hate to loose the headroom, also seems kinda tedious. Layers of thin flexible foam mat sound expensive and also a pain.
Expanding foam isn't cheap at $6 per can. I am on a budget. I could just do the roundest part, where wall meets corner/ceiling. Then the cheaper rigid board for the middle (relatively flat). Wallpaper or fabric to follow...
Regards,
Dennis (BeautyFool)
On the Edge in Sumas, WA
http://www.seanet.com/users/bronnz/blog/busblog.html
BeautyFool is offline   Reply With Quote
Old 02-23-2004, 10:56 PM   #18
lapeer20m's Avatar
i've yet to come up with a GOOD solution for insulating the ceiling.
If i lived in my bus, rather than using it primarily for parties, i would sacrifice head room for roof insulation. Height is not of primary inportance to me, i'm only 5'6" tall. That leaves me 6 or 8 inches to play with. If i build a bus to live in, i think i'd use 3 or 4 inches of fiberglass insulation on all walls and the cieling. My current bus is a bit drafty, and ton's of heat escapes through the ceiling.
I really have no plans to "fix" the roof of the partybus. I have a huge furnace (80k btu's) so i can keep warm, at the expense of buying lots of propane.
Old 02-24-2004, 08:51 AM   #19
Les Lampman's Avatar
Hi Dennis (BeautyFool),
Hello neighbor! I'm over here at the north end of Whidbey Island next door to Deception Pass.
I'm going to use cork ceiling insulation (don't think of corkboard stuff); it's has good acoustic properties, a good insluation value and isn't too thick. It should also be easy to apply; it's available in rolls and tiles (there's even a pre-glued, peel-n-stick version). I've found the material at The Cork Store.
I visited your site several weeks ago...cool!
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion"
Skoolie.net Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Old 02-24-2004, 09:44 AM   #20
Cork Celing
I think the Cork might be a great answer to walls & Celing. Thanks for the Information!!
How much insulation did you add to your bus? TygerCub Conversion General Discussions 8 03-09-2012 02:51 PM
? Insulation???? Six Four Everything Else | General Skoolie Discussions 3 02-20-2011 06:57 PM
insulation ???? jackling54 Conversion General Discussions 8 12-25-2010 10:42 AM
Insulation TygerCub Conversion General Discussions 7 08-24-2009 06:57 PM
All about insulation ollopa Conversion General Discussions 5 11-15-2006 10:26 PM
