Old 12-13-2015, 07:41 PM   #1
insulation
Alrighty...I gutted the entire bus, tore out old insulation and am now looking to put the new insulation in. Through reading other threads it seems the spray in foam comes most highly recommended followed by the rigid board. My understanding is that the spray in foam is stand alone.??(meaning no vapor barrier or silver bubble wrap needed) and if I use rigid board, is it recommended to use the silver bubble wrap up against the metal roof, floor, walls. before using the rigid board, and then do I use plastic for a vapor barrier on roof, floor, and walls before I put my final siding, flooring, ceiling on.??Apologies in advance..i don't mean to beat a dead horse..I know this topic is raised a lot...and there are some threads out there...I've just not found the answer for dummies.. I just want to know the order of layers from metal skin to final siding, ceiling ,floors if I use rigid board...Living in full time, 4 seasons.
ben berry is offline   Reply With Quote
Old 12-18-2015, 05:58 PM   #2
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I'm using 1" double-faced rigid foam on the side walls right now. I'll add some to the overhead later on. The floor is carpeted and has linoleum in the center and I'll have the underside sprayed this summer. Most of the side windows will come out and they'll be replaced with exterior grade plywood. Glass conducts heat/cold like you wouldn't believe. For the windshield, I'll cut some more rigid foam out of a 4x8 sheet. The driver's side window will be covered with an insulated curtain as will the door.
insulation
