Old 03-04-2014, 12:02 PM   #11
crazycal's Avatar
Re: Insulation added to outside of roof?
LOL, just kidding...kind of. This wil probably cost more than you paid for your bus.
I'm hungry!
You Gotta Let Me Fly
Old 03-04-2014, 01:14 PM   #12
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
No idea of the cost...haven't gotten that far yet. But I definitely need to keep the budget reasonable. If it costs too much I'll have to nix the idea.
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: http://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Old 03-04-2014, 01:32 PM   #13
Engine: 190hp 5.9 Cummins
Unfortunately, nothing good is cheap.
6 pound foam is $3 a square foot by 1 inch thick.
8' wide X 40' long = 320 square feet.
$1056 for 1 inch thick.
$1584 for 1.5" thick.
As long as your not walking on it, 2 pound would do fine.
2 pound foam is $1.10 a square foot by 1 inch thick.
$352 for 1 inch thick.
$528 for 1.5" thick.
As the density go's up, the coverage go's down. 4 pound go's half as far as 2 pound, ect.
Old 03-04-2014, 05:34 PM   #14
Locutus's Avatar
That 2 pound sounds affordable. The 6 pound seems steep though.
Hat tip to Lorna for turning me on to this article:
http://www.busnut.com/artgm04.html
Interesting point the author makes about expansion and contraction. I wonder if this issue could cause spray foam to delaminate from the exterior bus skin?
Probably wouldn't be any cheaper with that aluminum cover but might look better. I wouldn't need to insulate the outside of the end caps because they're made of moulded fiberglass and I could fill them with insulation when I remove the flasher lights.
Locutus
Old 03-04-2014, 10:52 PM   #15
crazycal's Avatar
I was going to guess a couple bucks a foot. I was checking prices recently and it was expensive. Then you need to do the fiberglass.
I'm hungry!
Old 03-05-2014, 03:22 PM   #16
Spray foam is basically plastic. It will contract and expand at the rate of the substrait it was sprayed onto.
So far I have never seen spray foam delaminate from anything. It even sticks to plastic vapor barrier.
I had to do two small demo jobs where a home owner made a big mess of wiring, plumbing, and studs behind a planned kitchen counter.
I started trying to remove individual wires, pipes, ect to make the needed changes. Even using a keyhole saw, utility knife, claw hammer, ect.
It was so hard to get apart, it took 4 times as long. My 10 pound sledge hammer, and the reciprocating saw were the main players. I had to cut the foam vertically between every stud, then smash the studs out with the 10 pound hammer. I had to remove everything they had done because everything was encased in a semi flexible, impact absorbing mass.
If all homes were built with this stuff, they would be 50% stronger. In our blue prints, when a home calls for foamed walls, the engineer will sometimes remover sheeting from interior wind thrust walls due to how stiff the structure becomes.
Old 03-13-2014, 07:34 AM   #17
didn't someone glue down 1/2 poly panels and then free floated a thin aluminum skin over it?(only attached at sides above windows and front/back)
the edges over lapped to move with expansion/contraction
It was down years ago and was still working after atleast 10 years on the road
Old 04-22-2015, 08:02 AM   #18
Chassis: I.H.
I keep thinking about going with this spray on roof foam. I love the idea and it seems like what I need. I am hoping cost is a regional thing. Since I am in Central FL but plan to travel, I could get prices based on location and wait until I get where it is cheaper.
Old 04-22-2015, 08:05 AM   #19
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Since I'm right near you, maybe we could get another bus owner or two to join us on trying to get a volume discount.
Worth a shot. I will be wanting insulation in a couple months.
Old 02-13-2016, 05:38 PM   #20
Has anyone actually used spray foam on the outside/ rooftop? How has it worked... sounds interesting
DRBW is offline   Reply With Quote
Roof insulation tomas_maly Conversion General Discussions 4 07-27-2012 09:44 PM
Roof over with insulation and ddpm lornaschinske Conversion General Discussions 1 11-28-2010 11:09 PM
External Roof insulation? n4matix Skoolie Conversion Projects 5 09-04-2008 10:24 PM
Page 6 added.... Vern1 Skoolie Conversion Projects 5 04-22-2004 08:38 AM
Added Rank Images Steve Forum Admin | Account Help | Suggestion Box 0 12-08-2003 01:35 PM
