Old 01-02-2008, 07:28 PM   #11
reprobate's Avatar
Re: Insulation options and best practices
Roastings8, I would think you would still want a thin sheathing over the insulation 1/4 or 3/8 to add some structural integrity, but I guess if you are not going to be walking up on top, the foam would do.
For insulation I lucked out. Next door neighbor is building a new house and wanted to use the spray foam in his attic. We went in together and bought a pallet of the stuff. 10 units to a pallet. He gets 9 and I get 1, but now I can spray my whole bus for about $450 and have good insulation and knock out any rattles and squeaks.
Dentarthurdent, I don't think injecting foam into the ceiling would be too effective because you already have fiberglass in there which I think would keep the foam from really being able to expand like it should or could.
reprobate is offline   Reply With Quote
Old 01-02-2008, 08:16 PM   #12
Chassis: All American RE
Engine: Cummins 8.3
I guess I need to open the ceiling and see what's in there. It sure sounds empty. Since my bus is from CA I thought perhaps it was not insulated at all. The more I think about it, the more I am inclined to take the ceiling down anyway.
I'd like to come up with a way to break the metal-to-metal contact with the outside without using up 4" of space. But I'd like to have a solid surface to glue a beadboard ceiling to so I may have to make it relatively thick. I am planning to raise the roof already - maybe toss in a couple more inches for insulation, etc.
dentarthurdent is offline   Reply With Quote
Old 01-02-2008, 08:40 PM   #13
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
You can see what's up there by pulling out a light fixture or speaker.
Most seem to have a couple inches of fiberglass.
As you say tho', there's the problem of the roof and ceiling being connected by the rib.
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 01-02-2008, 09:59 PM   #14
phillbus914's Avatar
I haven't done anything as far as adding insulation to my bus. I don't see it as being worth the time or money unless you're living in it full time in extreme weather. I could be wrong, I'm gunna try and test this theory out.
I'm trying to plan a weekend camping trip with my bus in a few weeks (if we can get a babysitter and enough people go to justify taking the bus) I'm gunna put my 30K BTU ventess heater to the test in my uninsulated bus . From freezing cold it's heats up comfortably within 10 min or so. I'm sure I'll use more propane vs. if I had insulated the bus better. It's been cold here avg. in the 20's and 30's... it's 12 out right now.
For the handful of times I camp in extreme weather, I think I'll be ok without added insulation. Only one way to find out! I'll let you guys know how well I keep warm.
My Old Bus :(
Old 01-02-2008, 10:59 PM   #15
Engine: Cummins 8.3
I'm mostly concerned about being able to keep it cool in the hot Oklahoma and Texas Summers - I can't sleep if I'm hot. Although it would be nice to make the propane last longer in Winter. I guess I'm saying that I'd like to have it insulated pretty well.
Old 01-03-2008, 07:21 AM   #16
reprobate's Avatar
Pulling the ceiling panels is a pain in the butt, but not really too difficult. To break the metal to metal I ripped some 2x lumber stock to 1/2" thick and then laminated (screwed) 3 layers of these thicknesses to the underside of the ribs. That now gives me about 3.5" of attic space and still 88+" of head room after an 18" raise. All that said, I am going to follow the existing curve in the ceiling and transition to the walls because I like the aesthetics of the curves.
Old 01-03-2008, 09:05 AM   #17
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Hi Reprobate, You're right about a thin sheathing over the insulation, but using metal would probably defeat the idea. Probably, if you put the sheathing under the rubber membrane (woo hoo, I remembered how the rubber lining is called) you might be on to something. I would still try to avoid metal, mainly because it would conduct heat easily.
The beauty about exterior insulation is you can add it at any time during the conversion. All that would be required is some paint to match up the roof with the rest of the bus.
Also, congratulations on your insulation score. I wish I could hit up on something like that.
BTW, how is your conversion coming along? If you're still working at the speed that you were, you should be just about done.
Robert
Roasting8 is offline   Reply With Quote
Old 01-03-2008, 09:10 PM   #18
reprobate's Avatar
Jimmyaustintx,
Search spray foam on the net. It's pretty much $1 a bd.ft. 1'x1'x1" thick. When I called a commercial outfit about it, they said anything over an inch thick is wasting your money. I bought the 605 bd ft set-up for $450 (free shipping) regularly $640 plus shipping. Will be delivered tomorrow, so hope to be spraying in a couple of days.
Yeah Roastings, I need to take some more pics. The wiring is done, measured for cabinets today, and as soon as I spray the insul. I'll be ready to start the interior panel work and window trim.
Old 01-04-2008, 01:07 PM   #19
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Hi Reprobate,
Where do you call home? It looks like you're either from AZ or NM. I lived in Phoenix before and I recognize the landscape.
Robert
Oops, I should read the other threads before writing. Ignore the sentence above.
Old 01-04-2008, 06:18 PM   #20
KC10Chief's Avatar
Rated Cap: 60
I really wouldn't worry about it. That's WAY too much trouble in my opinion. My bus is black on the outside! It doesn't get any warmer on the inside than it did when it was white on top. Even in the Oklahoma summer we had this year, it would be warm in there, but not as hot as my truck gets. The ceiling inside the bus was barely warm to the touch. On the outside, it's so hot you can't touch it. I don't think insulation in the roof is going to help you out very much. It also seems to hold the heat in well enough too. It's certainly nothing an RV furnace won't be able to keep up with in the winter. A 13,500 BTU A/C will be able to keep up with my bus even on the hottest day Oklahoma can dish out. I really wouldn't mess with insulating your ceiling if I were you.
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
http://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
These are my options opus Everything Else | General Skoolie Discussions 7 07-04-2010 06:33 PM
Insulation on a budget and wall framing options TygerCub Conversion General Discussions 1 06-23-2009 07:08 AM
How do I tell what options a bus has? zamfir Everything Else | General Skoolie Discussions 2 06-08-2009 08:33 AM
What Are My Options? retrogeek42 Conversion General Discussions 2 09-27-2008 08:22 AM
More options busone Conversion General Discussions 0 01-25-2005 07:56 PM
