Old 12-14-2012, 01:09 AM   #1
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Interesting heater
I saw this diesel heater for boats. It's much cheaper than I thought. $739
http://www.boat-heaters.com/103-dick...ne-heater.html
There is also this solid fuel heater that is very reasonably priced. $353
http://www.lfsmarineoutdoor.com/dick...FQtxQgodHF0AlQ
I'm hungry!
You Gotta Let Me Fly
Old 12-14-2012, 04:25 AM   #2
Moderator
crazycal's Avatar
Re: Interesting heater
This one has a cooktop. Hot water coils are available as an option.
http://www.boat-heaters.com/104-dick...ne-heater.html
I'm hungry!
Old 12-14-2012, 04:57 AM   #3
Engine: DTA360
Rated Cap: 16
A friend of the family owns a sport fishing charter out of West Port WA... I had my bus at a get together and was talking about diesel heaters and they had just given one away... It was a small marine one, I was pretty bummed out...
dirtygoat is offline   Reply With Quote
Old 12-14-2012, 05:17 AM   #4
Moderator
crazycal's Avatar
Why did they give it away? Was it broken?
I'm hungry!
Old 12-14-2012, 08:38 AM   #5
GreyEagle's Avatar
Might want to check with the Army surplus stores.....
The diesel heaters are simple to operate, fairly cheap to purchase and used..... You get a lot of heat for your buck $$$.
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 12-14-2012, 08:53 AM   #6
I remember I loved the diesel fired forced air heaters on are tanks,ours were high maintenece biggest problem was ignitors "dieing" diesel heaters work awesome!
I was kinda shocked at the low prices since I looked 6 months ago
Old 12-14-2012, 12:35 PM   #7
GreyEagle's Avatar
The ones we used in our tents where drip feed models. Consisted of a metal box, stove pipe, the tank was a 5 gallon can of diesel that we setup on a chair, log or whatever we could find.
and a regulator that controlled the drip. After we got it burning all it needed was a constant source of fuel. To get it started we would mix in a little mo-gas on the beginning to get it burning good
(not recommended if you're new at this) can you say FLASH!!!!! FIRE..!!!
then switch it over to diesel. It could run all night. Not recommended for use while driving or in a moving vehicle.
GreyEagle
Roll - On...
Old 12-14-2012, 03:03 PM   #8
Engine: DTA360
Rated Cap: 16
They gave it away because it had been sitting in the back of their office for a number of years... Someone asked about it and since they had one on every boat they gave it to the guy... Wish I could of gotten it...
Very interesting bus frank-id Everything Else | General Skoolie Discussions 13 08-19-2013 06:01 AM
Interesting Bus thewallfan Conversion General Discussions 9 07-27-2012 05:20 PM
DIY Heater for a Small Space: pulse jet heater lornaschinske Everything Else | General Skoolie Discussions 8 07-15-2012 08:54 PM
Very interesting bus F/S local. tfdfyrman Classifieds | Buy, Sell, Swap 6 08-02-2009 07:59 AM
This Looks Interesting.. What is it? wdbowers Everything Else | General Skoolie Discussions 4 01-07-2009 02:04 PM
