Old 07-12-2010, 11:59 AM   #1
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
Re: Interior Framing , Walls and Seats
Brad check out my thread I have pics of all that stuff. The walls (with insulation), etc. The benches are still a work in progress, I believe we have them 15 or 16" off the ground, then when you count the bus seat cushion it is 19". The backs are 40" or so high from top to the ground. The benches we have are 27" wide, not to bad really. Whatever we secured to the walls of the bus was with sheet metal screws and they were drilled into the metal in between the windows. Make sure your supports are about 14-16" between each one for proper support. We're making a storage bench right now, if you look in the past picture in my thread I think it shows it. Hinge and everything.
Rutgers tailgating bus https://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
Old 07-12-2010, 03:18 PM   #2
Scratchy's Avatar
Engine: 5.9 Cummings
GoBucks64,
Not sure exactly what you are looking for in regards to benches, but I'd recommend checking out Downsouth's gallery for the benches in his bus as I don't have any pictures of my mine posted. He was a huge help for me when I was building my benches. I built mine similiar to his design. Make yourself a tapered leg jig for the back uprights to keep the angle consistant through your table saw and your home free.
Scratchy
Scratchy is offline   Reply With Quote
Old 07-13-2010, 08:25 AM   #3
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Here's what I did. I used "L" brackets to prevent movement in all three planes. Check out my thread on the fifth page "Big Mac for $500". You can see where I used self-tapping sheet metal screws to hold it all in place. It's so strong I can hang from the side of the cabinet (and I'm a bit chunky).
M1031 is offline   Reply With Quote
Old 07-14-2010, 09:16 AM   #4
Do bus chassis flex much? I'm just wondering if the framing may loosen up over time.
danielm is offline   Reply With Quote
framing, and installation of walls. katburlie2690 Conversion Tutorials and How-to's 7 09-10-2014 10:47 PM
How to build interior walls wmkbailey Conversion General Discussions 7 06-30-2014 04:55 PM
framing questions nate1191 Conversion General Discussions 16 12-22-2011 07:42 AM
Framing the floor AndyRalfano Conversion Tutorials and How-to's 0 07-27-2011 12:21 PM
Framing the interior Firearm Conversion Tutorials and How-to's 15 04-17-2011 08:07 PM
