Old 11-14-2009, 10:06 AM   #1
Chassis: Ford B700
Engine: 5.9L Cummins
Interior Hidden Fasteners
Has anyone used any sort of hidden fasteners when building their bus interiors? For my next project I would like to have some vinyl covered and also painted custom fiberglass trim panels but dont know how to fasten them without having holes or screws in the front of them.
kamoo is offline   Reply With Quote
Old 11-14-2009, 01:10 PM   #2
thesaltydog24's Avatar
Re: Interior Hidden Fasteners
I was thinking about this and even did a google search but that came up with a lot about deck fasteners. if its just trim and nothing load bearing then I would say try something like liquid nail or other bonding agent. but you would run into the problem if you had to remove it for whatever reason.
Chris
thesaltydog24 is offline   Reply With Quote
Old 11-14-2009, 05:27 PM   #3
TygerCub's Avatar
Engine: Detroit
If it is permanent fixture, then I'd also say use Liquid Nails. However, if it's a panel you need to remove occasionally, then I'd suggest using industrial velcro. Six inch strips at each corner will hold the panels on tight, but still be removable when necessary without showing any fasteners.
Old 11-16-2009, 11:11 PM   #4
sportyrick's Avatar
Chassis: F33695
two words contact cement! sportyrick
Some interior shots SpongeBob Skoolie Conversion Projects 1 03-15-2010 01:41 AM
Interior Dimensions Seeria Conversion General Discussions 5 11-04-2009 07:43 PM
Interior Lighting the_experience03 Conversion General Discussions 5 10-23-2009 06:41 PM
interior paint Jody Conversion General Discussions 7 08-14-2006 01:23 PM
Interior height Gweedough Conversion General Discussions 6 02-06-2006 11:55 PM
