Old 02-17-2009, 10:02 AM   #1
Papabear's Avatar
Coachwork: ward
Chassis: IH
Interior roof & Flasher removal
Calling out to the Bus GURU'S What's up with the roof on the inside? Over the drivers area the roof is skinned with a perforated liner and a 6" (approx) vent. Does the vent have to stay? Why the different material from the rest of the bus? I want to make a headliner and cover this but not sure if there will be a condensation problem or what.
Has anyone removed all the wiring, flashers, relays from their bus? I want to get rid of all uneccessary wiring and switches. There is a buttload for wiring behind the main panel with what I think are relays. Not sure where the flasher units are located. Are those lights all 12 volt or 24 volt?
Thanks all
"I've never been lost, but I been mighty confused for several days"
Papabear is offline   Reply With Quote
Old 02-18-2009, 08:40 AM   #2
Papabear's Avatar
Coachwork: ward
Chassis: IH
Re: Interior roof & Flasher removal
The "acoustic panel" makes sense. I have it only over the drivers area. I'll be covering in with a plastic vapor barrier and a headliner. The electrical is another matter. It looks as though there had been updates made in the console I.e. side stop sign. It is a bundle of sheit when you open up the electrical panel. Think I'll just jump right in and ask a lot of questions after nothing works
Thanks Guys
where is the flasher?? gbstewart Conversion General Discussions 8 07-10-2019 10:03 AM
Interior wall removal question? sickrunvanyardsale Conversion General Discussions 4 06-03-2014 01:15 PM
Roof screw removal burnthebus Conversion General Discussions 5 05-15-2014 10:03 PM
Painting interior roof with Solarflex? TygerCub Conversion General Discussions 9 04-30-2012 03:31 PM
Interior Panel Removal Bullwinkle Conversion General Discussions 6 08-28-2006 12:50 PM
