Old 03-12-2019, 01:22 PM   #1
Dead pirate's Avatar
Chassis: amtran
Engine: international md 3060
Rated Cap: 13 ton or so says the tit
International instrument cluster
Got this second bus almost ready to start but the cluster is done.
Dead pirate is offline   Reply With Quote
Old 03-12-2019, 02:40 PM   #2
it doesnt work at all? thats a communicating J1708 Cluster.. there are a lot of these on most of the 'E' busses from 97 / 98 on up.. this cluster is specific to the Diamond Logic Computer.. which was used mid 97+.. you can tell if you have the right oine because the oil pressure gauge is a 90 degree and not a 270 degree sweep, and the temp gauge maxxes at 280. and not 230. all the gauges except air and fuel-level on that cluster are readable with a scan tool like scangauge D or bluefire
Old 03-12-2019, 02:57 PM   #3
Chassis: amtran
It wasn't even in the dashboard. It's smashed and missing parts. It's a hot mess. I need to know what's going on before i fire this rebuild up. It's my last big hurdle.
Old 03-12-2019, 04:19 PM   #4
Is the harness there pirate, in good shape? That would give you temp, volts, oil pressure, maybe air pressure. Just missing tach, speedo and fuel but that would let you start it up with some instruments possibly.
Just a thought until you find a good one.
Nice work you have done getting it ready, hope she purrs!
Old 03-12-2019, 04:55 PM   #5
Do you have access to a scangauge D or bluebird? The senders all talk cto the ECM for the oil water volts RPM and MPH, that panel is data terminal on the J1708 bus..
you’ll need to hook the air gauge up on that or your air will just leak out instantly.
Christopher
Old 03-12-2019, 05:16 PM   #6
Chassis: amtran
No. But i will check it out. That monitor dashboard setup you had was sweet. Is that what you are talking about here?
Old 03-12-2019, 05:18 PM   #7
Chassis: amtran
The harness is there but none of the actual gauges are in it. I would only have air pressure. The board isn't in it.
Old 03-12-2019, 08:20 PM   #8
Ok, gottcha, well that doesn't leave many options for you. Someone must have something out there, keep digging and we can also.
Best of luck,
Old 03-12-2019, 08:22 PM   #9
Chassis: amtran
Thanks. I'm sure one will turn up. They aren't that rare. They come unsoldered and need fixing often but someone has one.
Old 03-12-2019, 08:22 PM   #10
geminusprime's Avatar
Chassis: Vista 3600
Engine: DT466E / AT545
The Scangauge is a smaller 2 line LCD screen that displays 4 gauges (in digital form), and attaches to your ECM connector. I had a touchy instrument cluster that liked to go dead (bad solder), and I got the Scnagauge as a backup but now use it mostly instead of my dash cluster.
Also tracks gas mileage and gives you a lot of details you wouldn't get on the regular cluster, such as horsepower output, load, and other cool stuff.
This is the one I got, scangauge 2.
geminusprime is offline   Reply With Quote
