Old 10-25-2012, 08:10 PM   #1
inulation for floor
What's everybody doing for the floor. My wife and I are going to end up living full time in it and don't want to have a cold floor in the winter in Utah. I'm not sure how thick and what kind of foam board to use. Then I was thinking 3/4 inch plywood. Then grey or tan rhino lined with big rugs throughout. And I guess the same foam on the And walls I'm just unsure what everybody's done and what works.
rancid0076 is offline   Reply With Quote
Old 10-25-2012, 10:51 PM   #2
opus's Avatar
Chassis: All-American R/E
Re: inulation for floor
I used 5/8 plywood and 1.5" of pink board under it.
Old 10-26-2012, 07:26 AM   #3
how does it do in the winter, what did you do on the walls and roof.
Old 10-26-2012, 09:26 AM   #4
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
There are more answers here. It is the Conversion Discussion of this forum.
viewtopic.php?f=11&t=13459
Old 10-26-2012, 09:35 AM   #5
Send a message via ICQ to mightybus
If you will be stationary, skirting the bus works wonders.
mightybus is offline   Reply With Quote
Old 10-26-2012, 10:22 AM   #6
opus's Avatar
Walls I did the same. Windows all we have are insulated curtains. Didnt do anything with the roof and thats the biggest problem. There isnt too much you can do unless you want to drill about 125,000 rivets!
We're not stationary much, just overnight and we have a Webasto and a lot of heaters in the bus so its not an issue.
Old 10-26-2012, 12:34 PM   #7
crazycal's Avatar
LOL, you must have a BBAA. Yours only has 125,000 rivets? I think mine has about 300,000. That's one of the things I like about the Internaional I'm working on right now, almost all the steel on the inside is held in place by large screws. Your BB will be much stronger rolling down the cliff but I will still live longer with my International because I would commit suicide trying to grind down all those rivets. I wouldn't live long enough to have an accident and roll off of a cliff.
I'm hungry!
You Gotta Let Me Fly
Old 10-26-2012, 02:12 PM   #8
opus's Avatar
I was only counting every other rivet, for times sake. I messed up a few times and had to start over. ;)
I find nothing you can do to the ceiling, so that is how I left it.
almost there with the floor butcher_boy Conversion General Discussions 2 06-07-2011 12:33 PM
Rubber floor recycler Conversion Tutorials and How-to's 2 06-08-2009 02:40 PM
Pergo floor first. bus-bro Conversion General Discussions 2 10-08-2008 11:22 AM
3/4 ply vs 3/4 osb for floor busone Skoolie Conversion Projects 6 10-09-2005 09:07 PM
inulation for floor rancid0076 Skoolie Conversion Projects 7 12-31-1969 07:00 PM
