Old 05-12-2005, 06:26 PM   #1
Inverter/electrial questions
Is there a source online for electrical layouts in a bus? What i am looking for is an explanation of how everything is phyiscally wired in, can you use a regular inverter to run accessories or does it have to pass thru a breaker box, how is the 30 or 50A service wired into the bus, things like this. I looked at the electrical stickies but am still lost what i am looking for is a heads to tails explanation, not worried about the 12v, ive got that but from the 110v side how is it physically done?
Thanks!
~B~
1979GMC6000 is offline   Reply With Quote
Old 05-24-2005, 04:05 PM   #2
now are you talking about running just inverters? or inverters and a generator, at times. and what are you wanting to power, tv, coffee pot, microwave, exc: im running duel air, coffee pot, microwave, my inverter whitch runs my 12 volt, lights, pump, you get the idea, your best bet if you know nothing about electrical is find a freind who knows one and supply beer one weekend for some help lol. or just pay alittle it all worth it in the end. i'll help you as much as possible. if i can.
heath692 is offline   Reply With Quote
Old 06-04-2005, 02:34 PM   #3
Firearm's Avatar
Send a message via ICQ to Firearm Send a message via AIM to Firearm
I have a question about inverters. How much power woule I need to run a TV and maybe a microwave and a small dorm sized fridge? These are about the only AC powered items that I am thinking about putting in the bus and I want to buy an inverter that will handle them without buying a lot more than I need.
Firearm is offline   Reply With Quote
Old 06-04-2005, 04:14 PM   #4
If i remember right(now correct me people if im wronge) for every 100 watts = 1amp. so with that in mind if your microwave pulls say 7 amps on high, and your coffee pot pulls 4 amps, and your tv pulls 3 amps you have a totol of 14 amps with everything running. whitch would = 1400 watts. so you get the idea ohh and dont forget about your frige. now im just throwing numbers out there but you get the idea. look on all your items and figure what they all draw. and myself i would give yourself extra. say everything pulls a total of 2000 watts get a 3000 watt inverter to give extra if need. and also it dont work as hard. and the reason for alittle bigger is you know as well as i do just when you think you have enough. you need more. i hope this helped in your quest for power.
Old 06-04-2005, 06:48 PM   #5
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Electrical Stuff
The book, RV Electrical Systems, which you can find on Phred's Poop Sheets (google that and look for his electrical info), is what I used. Essentially, the physical aspect of the electrical wiring is the same as household electrical wiring.
The electrical service line comes into the breaker box ("mains breaker" type box, with the MAIN BREAKER, not a "mains lug" box with no main breaker). 30 Amp installations use one 120 VAC supply line. 50 Amp installations use 2 120 VAC supply lines. (You could actually hook up a 240 VAC circuit in your bus if you had some kind of power equipment that required it.)
The incoming ground wire gets wired to the breaker box on the grounding lug strip. The ground wire should also be wired to the chassis of the bus. That is very important. The ground lug strip is the one that is physically connected to the breaker box itself. If you use regular household "Romex" cabling, the ground wires will all be bare copper wire. That is fine. Just be neat with your wiring, and don't let them touch any of the hot or neutral wires where they might make electrical contact with the tips of the wires in the breaker box. (Boxes are designed to make this difficult anyway.)
The incoming hot wire(s) gets wired to the breaker box at the main circuit breaker.
The incoming neutral wire gets wired to the breaker box on the neutral lug strip. The neutral wiring should be "floating", that is, not connected to the ground wire or the chassis (which is a ground) anywhere in the bus. THIS IS VERY IMPORTANT. The neutral lug strip is the strip that is insulated from the breaker box, usually on raised insulated posts, and with a shielding strip that will keep the neutral wires from sticking through the lug strip and contacting the breaker box.
There is a simple formula for Watts/Amps/Volts. Watts are Volts times Amps. You sometimes see them referred to as Volt-Amps. Volts are Watts/Amps. Amps are Watts/Volts.
There is a tenfold difference in AC and DC voltage, so AC Watts and DC Watts are different because because they have different voltages. I didn't say that exactly properly, but here's how it works:
120VAC * 10 AMPS = 1200 Watts
12VDC * 10 AMPS = 120 Watts
or
120VAC * 1 AMP = 120 Watts
120VDC * 10 AMPS = 120 Watts
If you find the Wattage of an item (reefer, tool, pump) and know its operating voltage, you can determine how many Amps a circuit will have to carry in order to run the item properly.
Reefer @ 1500 Watts on a 120 VAC line uses 12.5 AMPS for continuous operation. Some equipment uses as much as 3 times its running Amperage to start, particularly equipment with motors in it. This surge demand has to be accounted for in designing a circuit.
Wire sizing is important. A wire sized to carry, say, 20 amps on a 20 amp circuit for the example of the reefer above could run the reefer fine at 12.5 Amps of current. It could also handle the 37.5 Amps that the reefer requires to start its compressor motor on a momentary basis , but it could not handle a continuous load of 37.5 Amps -- it would heat up and maybe cause a fire.
The book I mentioned goes into great detail about all of this, circuits, wire sizing, etc. (as do other books, but I have read the one mentioned above).
Circuits are very simple, essentially, even in RV or household wiring. They work just like the Radio Shack kids' electrical experiment circuits, only the wires are longer -- and the goal of making them is NOT to see how big a spark you can make!
Eric von Kleist is offline   Reply With Quote
Inverter FAQ's lornaschinske Conversion Tutorials and How-to's 4 08-13-2012 08:15 PM
What Inverter To Get? lapeer20m Conversion General Discussions 1 05-14-2010 12:31 PM
Why use an inverter? lapeer20m Conversion General Discussions 5 09-07-2008 05:01 PM
UPS used as an inverter. Steve Conversion General Discussions 13 04-19-2005 07:43 AM
Have you had anything damaged by an inverter? trx Conversion Tutorials and How-to's 2 04-05-2005 05:06 PM
