Old 04-03-2008, 04:42 AM   #1
just got new rear end 5.57?
so i just delivered my new wheels and axle housing. and it turned out to be a spicer witha 5.57 ratio. i had an old 6.5 or 650:1. did i just buy the same problem over again? or is this a good ratio? we had been talking about how a 4.44 would be most desireable
thanks
adamanderr is offline   Reply With Quote
Old 04-03-2008, 04:58 AM   #2
lapeer20m's Avatar
Re: just got new rear end 5.57?
if you had a 6.5 before, then a 5.57 is a step in the right direction, but still not that desirable. I've had that rear end in 2 buses, and really wish i had a better rear, like a 4.44. i don't think you would want to go any more conservative than 4.10.....if you had a 3.73 for intance, depending on the powertrain your engien probably wouldn't produce enough torque to drive the bus down the road in top gear.
if i were gonna change out a rear end, i'd work hard to find a ratio between 4.10 and 4.44.
my bus with 5.56 was getting 6.5 mpg when phill with 4.44 ratio and the same size bus and same size engine was getting 10-12 mpg when we went on a trip together. It wouldn't take long to pay for the better gear ratio....especially with fuel above $4/gallon
Old 04-03-2008, 09:32 AM   #3
sportyrick's Avatar
Chassis: F33695
Engine: 427 chevy
That ratio will be better than you think. Give it a try and let us know what you think. You don't want to go too high or you will lose power to the point that you won't be able to climb a hill and do 100 MPH down the other side. Your 6.5 would be better than my 6.83, is it a spicer? I am not interested in changing my whole housing, just the pumpkin. Everything is a compromise. sportyrick
Old 04-07-2008, 10:52 AM   #4
Engine: 7.3 diesel
I had mine changed from 5.57 to 4.33. I gained about 2 mpg. If I wanted to gain more I think I would need a turbo on this 7.3 to give it more kick. On the flats it does alright right now but once I hit a steep hill going up it does slow down to the point where people pass me to get in front of me and then I have to re pass them on the down side. I can run 75 down hill without my foot to the floor. Ideally I like it at around 55 to help safe fuel money. My top speed before was around 57.
Those of you with rear decks... busdriver_phil Conversion General Discussions 5 04-30-2010 09:32 AM
Big Rig Rear End... NewSkewlHauler Conversion General Discussions 11 04-01-2009 03:25 PM
Rear Deck on Bus... aceinthehole2220 Skoolie Conversion Projects 7 07-30-2008 10:49 PM
Looking for a new rear end phillbus914 Classifieds | Buy, Sell, Swap 3 04-20-2008 11:28 AM
Rear storage / Rear door ideas allanwcoty Conversion General Discussions 0 05-17-2005 11:52 AM
