Old 01-04-2016, 04:47 PM   #1
Big11beard's Avatar
Engine: CAT 3126 7.2L
Kayak Rack
I need a cheap solution to mount the two 10ft kayaks on top of the bus without blocking the solar panels to much. I found a 6ft x 5ft section of fencing at the metal yard for $15. I ran 1in steel tubing and pipe fittings through the center of the fence an bolted through pipe and fence.
In front I drilled holes through the bumper. On top of the bus I cut oak blocks so a level pipe flange sat flush to the bus and sealed with black tar. 1/4" threaded rod goes all the way through the roof.
See The Entire Project:
www.eljardinometepe.com
Big11beard is offline   Reply With Quote
Old 01-04-2016, 06:45 PM   #2
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
I like it!
Old 01-04-2016, 06:50 PM   #3
Sweet. I'd like to see it with kayaks.
MuddyG is offline   Reply With Quote
Old 01-04-2016, 07:20 PM   #4
Big11beard's Avatar
oh... you'll see it with the Kayaks. Our overlander adventure to the tropics begins on or around Feb 5th
Old 01-05-2016, 07:55 AM   #5
be advised you will get a lot of torsional twist and the rear mounts may break
How do you plan to put kayaks? if they are 10 ft, they will hang over a foot on each side, or they will hang over roof 5 feet, will that lead to vibrations and the kayaks resting on panels and possible cracking them?
You guys will have a ball, stay safe and have fun!
Old 01-06-2016, 09:59 AM   #6
Big11beard's Avatar
What I can say in confidence is that Almost everything I have built on this bus is questionable from my Mechanical Engineering perspective. Unfortunatly my wife points out that if I did everything "right" then we would have a $30k bus and not a $10k bus.
So we take it slow. Fix it when it breaks. And most importantly keep it Getto Fabulous.
Old 01-06-2016, 09:59 AM   #7
Big11beard's Avatar
More Photos at our blog Gallery
https://eljardinometepe.wordpress.co...ory/galleries/
Old 01-06-2016, 10:11 AM   #8
Chassis: B3800 Short bus
Huh.. Neat idea with that front rack! Reminds me of the car carrier trucks:
I'm looking forward to seeing pictures of the kayaks up there.
Mesh (or fencing in your case) is probably a good material for that location since I'm guessing it will have a strong updraft going through it at highway speed.
jazty is online now   Reply With Quote
Old 01-06-2016, 01:57 PM   #9
a lot better pictures, the pipe and couplings won't break
those pictures show it alot better built than first ones
how will kayaks go on?
Old 02-17-2016, 08:33 AM   #10
Big11beard's Avatar
The Kayak Rack has been working great. The back end of the kayaks shades a little of the solar panel but, I have more then enough power being collected from the panels. The kayaks can only be seen from the driver seat if you lean forward. They sit slightly above the solar panels so they also double as a clearance check for tree branches and such.
