Old 07-18-2019, 09:42 AM   #1
Keeping Stop Sign Arm
Hey all! I have removed the actual red stop sign from the arm it is attached to. I am planning on leaving the mechanical housing though to avoid opening another hole in the side of the bus. I have 2 wires with lights attached to them hanging down that went to the red lights that were on the actual sign. My question is: can I just cut these 2 wires, cap them off, then just push them into the mechanical housing? I have already disconnected the fuse that controls the stop sign arm.
We may use the arm in the future to place another sign of some sorts, so Iíd like to keep it.
Thanks everyone and anyone!
File Type: jpg 543B1BAE-5056-4512-9E25-6916453E406E.jpg (188.9 KB, 2 views)
File Type: jpg 2D03DB39-9F9C-4A47-9C39-3A6C0B00931C.jpg (182.7 KB, 2 views)
File Type: jpg 2F62964D-5A16-4B1F-BB4C-ACDACB454A99.jpg (180.8 KB, 2 views)
rydawg3000 is offline   Reply With Quote
Old 07-18-2019, 10:10 AM   #2
Wire nuts on the ends to keep them from accidentally grounding and you should be fine.
Old 07-18-2019, 10:24 AM   #3
We may use the arm in the future to place another sign of some sorts, so I’d like to keep it.
The holes in the side left behind by these are pretty minor, like four 1/4" screw holes and two 3/4" holes with grommets that the wires pass through. Pretty easy to bondo over them (front one is slightly tricky since the big holes are close to a panel seam, at least on my bus). I can understand wanting to keep them, though - I was originally going to put big smiley faces on them before I realized I had too much on my plate already.
Old 07-18-2019, 11:12 AM   #4
Thanks o1marc! Just wanted to double check because they had the lights attached to them.
Old 07-18-2019, 11:15 AM   #5
Oh nice, I’ve just heard stories of people having really large gaping holes. Either way, I’m going to try and keep it- maybe I’ll execute the smiley face idea one day!! Thanks for the help musigenisis
Old 07-18-2019, 11:28 AM   #6
Oh nice, Iíve just heard stories of people having really large gaping holes. Either way, Iím going to try and keep it- maybe Iíll execute the smiley face idea one day!! Thanks for the help musigenisis
I read similar stories about removal problems but taking them off was probably the easiest thing I've done on the bus so far. I think maybe it's just the International sign mechanism that is easy to remove.
Old 07-18-2019, 01:12 PM   #7
TheHubbardBus's Avatar
Coachwork: IC
Engine: Navistar T444e
Rated Cap: 24
We're absolutely, positively keeping ours. We haven't figured out exactly what it will be used for, but it will be used for something, and that something will be super-cool.
- Sharon & Jody
Old 07-18-2019, 04:48 PM   #8
I was thinking making mine a clock that shows 4:20. But it would be a cop magnet in every illegal state.
Old 07-18-2019, 05:06 PM   #9
Coachwork: IC
Rated Cap: 24
You could make it a digital clock. Show the actual time when retracted, then 4:20 when extended (with the flashers intact, of course)
- Sharon & Jody
Old 07-18-2019, 05:09 PM   #10
I do like the lighted number panels on race cars now and have considered checking them out. They now have lighted plates on some cars that tell you what position they in at the time. Counting the pit stop time, etc.
stop arm, stop sign
