05-02-2011, 06:59 PM
Chassis: Tc2000
Engine: 5.9 Cummings turbo diesel
Re: Ladder for Bus
Great nations rise and fall. The people go from bondage to spiritual truth, to great courage, to liberty, to abundance, to selfishness, to complacency, to apathy, to dependence, and back again to bondage.
05-02-2011, 08:00 PM
Rated Cap: 89
Re: Ladder for Bus
We also want to get one of the telescoping ladders. Makes more sense than trying to carry the standard "A" type ladder we have now (that is also slightly too short for me to climb up on the roof). The telescoping one can be slid up in the storage area under the bed. Although the prices vary pretty widely.
http://shopping.yahoo.com/search?p=telescoping%20ladder
05-02-2011, 09:14 PM
Engine: DT466/AT545
Re: Ladder for Bus
Are you going to permanently mount it, or does it have to be freestanding? If permanent, then what about making one out of black iron piping? I'll bet you could find the right fittings and just screw it together. Downsides might be weight and perhaps rust. I'm not sure what it would cost...
05-06-2011, 11:04 PM
Chassis: International Amtran RE
Engine: DT466E/MD3060
Re: Ladder for Bus
One suggestion is to make it out of rebar? It bends somewhat easy for fabbing but when welded together its very strong as well as light weight. You could put pipe on the bus and hook the rebar on it like a coat hanger? Just a thought? It would be way less than 400 but the black pipe is a very good idea.
05-07-2011, 07:12 PM
Engine: T444
Rated Cap: 22
Re: Ladder for Bus
Silly thought but would it be possible to retrofit an old RV ladder to a bus. There must be salvage sources for old RV extras.
05-18-2011, 10:31 AM
Rated Cap: 89
Re: Ladder for Bus
For a skylight that you can also use as an access to the roof, you need an emergency hatch. Try Defender Marine or West Marine and look under their boat hatches for the size you need.
05-18-2011, 10:15 PM
Rated Cap: 89
Re: Ladder for Bus
[quote="Iceni John"... Don't be like the folk with older MCIs who cut through the main longitudinal roof member, then wonder why their bus later begins to sag behind the rear axle - that roof rib supports the engine and transmission, so without it everything goes pear-shaped.
John[/quote]
Basic rule... don't cut holes in a monocoque coach!
03-25-2024, 01:34 PM
Chassis: International 3600
Engine: 7.3
I was thinking an 8 ft ladder or possibly a 10 ft both with hooks on the tops rotatable and definitely collapsible
03-25-2024, 07:57 PM
Rated Cap: 37,400 lbs GVWR
For folk with pushers, I have a 6' aluminum step ladder that sits on an aluminum frame under the driveshaft, pivoted at the right-side end so the left-side end will swing down to the ground after two simple catches are released, then the ladder can be easily slid out. This way the ladder is out of the way, but it takes only a minute or two with no tools to access it. It's completely secure under the driveshaft, occupying otherwise unusable empty space, but the only downside is that it gets blobs of grease on it after I've greased the driveshaft and it flings the excess out while driving!
03-25-2024, 07:59 PM
I duplicated my post, but now can't delete the duplicate. WTF?
03-25-2024, 10:01 PM
For ladder: put rock climbing pegs!
How about those rock climbing wall "pegs" like they have at a gym!
03-26-2024, 05:11 AM
Ha ha I don't think many of us are young and athletic enough to use those.
03-26-2024, 09:48 AM
Chassis: Chevy P30
Engine: Chevy 6.2L Diesel
Even for those of us that are athletic enough to use those, one generally does not climb up on the roof to sit up there.
The vast majority of the time the weather isn't suitable, and when you are trying to get on top, it's usually with some kind of toolage or heavy luggage, and you're really going to want the stability of a regular kind of ladder.
03-26-2024, 02:11 PM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
Telescopic ladder
I bought 12ft ladder used $50. The last four or five years, I rarely buy new stuff. I usually find things as good as new for 50% less than new prices.
William
