Old 07-31-2005, 09:36 PM   #1
vonslatt's Avatar
Engine: CAT 3208 NA
Lady Propane
I just finished hooking up my stove and I wanted to test. I connected one bottle to the automatic change-over regulator I bought and gas came out the other bottle connector when I opened the valve.
Must an auto-changeover regulator have two bottles connected to it at all times? Is there a "dummy" plug available that would let me run on a single bottle?
Thanks,
Jake.
My 1989 Thomas Saf-T-Liner
vonslatt is offline   Reply With Quote
Old 07-31-2005, 09:45 PM   #2
Send a message via AIM to noahyay
i honestly wouldnt know but it would make sense that the tank that isnt there has a lower pressure and therefore the regulator would switch to the full tank. you might want to watch it getting low though.
7.3l td 14pass e350 -saved: 1k -goal: 4k
noahyay is offline   Reply With Quote
Old 08-02-2005, 05:07 PM   #3
Re: Lady Propane
Thanks,
Jake.
Yes you have to have both hoses connected and yes you can get a plug at least for the older fittings.
Garry
Garry is offline   Reply With Quote
Old 08-02-2005, 09:43 PM   #4
vonslatt's Avatar
Engine: CAT 3208 NA
Thanks Garry!
Lady Liberty Tour bus convertion 34Speedster Skoolie Conversion Projects 11 09-26-2013 07:53 AM
3.44 MPG on Propane -- Yikes! the_experience03 Alternative Fuels | Electric, Propane, Wood & Biofuels 8 08-04-2011 09:51 AM
Where do I put my propane?? jkindt Short-Bus Conversion Projects 10 03-02-2010 07:54 PM
new propane tank stuckincalifornia Classifieds | Buy, Sell, Swap 4 02-10-2010 11:18 PM
Lady Franklin-Building Good Energy On Wheels Lady Franklin Skoolie Conversion Projects 4 04-04-2009 05:59 PM
