Old 06-25-2017, 10:16 PM   #1
Laminate flooring or Tile or linoleum or ???
Hello All! I need advice please. I'm renovating a shuttle bus to be a mobile art classroom on wheels. It will be used by preschool & elementary age kids. I want to know what flooring is best in the long term. Consider of course that paint, glue or other liquids could be spilled. Now I'd like the look of wood laminate flooring and it creates the atmosphere I'm going for but is it really right for my needs?
Anyone have an opinion? Thanks ahead of time for your comments.
-Mike
mpn7777 is offline   Reply With Quote
Old 06-25-2017, 10:26 PM   #2
I saw a bus conversion where he used marine grade floor material but I can't remember what it was. It was ugly, but thick, solid, waterproof, etc. If I find out what material it was I'll let u know, that would be my choice.
Iheartbus is offline   Reply With Quote
Old 06-25-2017, 11:20 PM   #3
Iheart may be talking about Better Life Technologies LLC's 'G Floor'. They have several floor coverings, and may have something for you. I do agree that their bus line was a little ughhhh.
1olfart is offline   Reply With Quote
Old 06-25-2017, 11:27 PM   #4
jctrembly's Avatar
Chassis: Amtram RE
Engine: 466 250hp HT
With any wood laminate read the fine print. Most of them are required to be installed in a temperature/ humidity controlled environment with very little fluctuations.
I have used an Luxurious Vinyl Tile "LVT" with a rubber back for sound deading in apartments that has held up very well. Most of these are glue down, but in a bus I would prefer to glue it to at a min exterior grade plywood. Most Walmart have a type of LVT glued down in the clothing section. I sure that is one of the more extreme environments a floor will suffer through.
Sent from my Nexus 5X using Tapatalk
jctrembly is offline   Reply With Quote
Old 07-01-2017, 03:17 PM   #5
Well just to give you some feed back on snap laminate in the bus world. I installed mine last year on the fall. It was cool and damp air. Now that it is summer, the air is hot and dry. My floor has developed gaps due to it shrinking in the dry air. Not a big deal for me, but something to keep in mind.
Oldmopars is offline   Reply With Quote
Old 07-02-2017, 07:12 AM   #6
The big blue bus's Avatar
If you are expecting spills or will need to mop etc you should just use a vinyl.if you like the look of wood they have designs with wood.its cheap and will not be bothered by moisture.
The big blue bus is offline   Reply With Quote
Old 07-02-2017, 09:06 AM   #7
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Howdy Mike, since you asked...
I love tile but it is HEAVY!
Given your description (lots of kids), vinyl is probably the right choice. The current 'version' of vinyl is fairly inexpensive and very easy to install - particularly the 'floating' type that does not need staples, glue, etc. It is pretty tough but is very easy to replace when you decide you want a new look - or repair some damage. Plus, you can get nearly any color/look you want - including a wood floor.
JD - Full timer out west
My Adventures & Build
Old 07-02-2017, 12:56 PM   #8
Just a couple of thoughts...
Wood is beautiful but subject to expansion & shrinkage. And from what I have seen does not hold up well to the concentrated wear patterns in most RV's & buses (everyone walks the same aisle).
The Pergo type flooring has such a very thin surface of color or woodgrain that wears and scratches through fairly easily. Also subject to swelling when wetted. Most are wood-based substrates.
Ceramic tile wears great but the vibrations and flex of a bus chassis will crack either the tile or grout pretty quickly.
Vinyl tile or planks are pretty very well suited to bus life. Good wear, easy to clean and not affected by water/moisture or flexing.
Bamboo looks good but has most of the drawbacks of any wood product.
Linoleum resists moisture but the surface of most of the roll type is very thin and easily scratched or torn. If the color is all the way through and it's not just a thin surface layer, it does not show as much.
Vinyl... Armstrong commercial vinyl tiles are tough as nails and easy to keep up. Roll vinyl flooring is usually not as tough but has most of the same advantages. Waterproof, easy to clean and very durable. That's why you see so much of it around.
Commercial carpet can actually hold up pretty well but it stains and holds moisture and dirt like crazy.
Soft rubber flooring will help kill sound and feel good under your feet but does not hold up well to traffic.
Hard rubber flooring, whether roll or in tiles, helps cancel sound, is waterproof and easy to maintain and can last for decades. The good stuff (like Pirelli) is expensive but as with most things, you either get what you pay for...or pay for what you get.
There are other possibilities and I would encourage everyone here to chime in with their experiences or opinions on these and any other possibilities.
And one last thing...remember...the wear patterns in a bus are very concentrated. 98% of your traffic will be within a narrow path down each aisle. Installing whatever you use in such a way that you can fairly easily replace the high traffic, high wear areas will make life much easier down the road.
Old 07-02-2017, 03:10 PM   #9
for the last two busses i converted, i used the pergo type flooring, and never have had any problems with swelling, etc. I even purchased many many sheets of flooring rejects from the mfg company in washington, and used some of them on my outside deck at my house n it rains a lot in oregon... this flooring has many uses esp if one purchases it before it is cut into strips..
Old 07-02-2017, 03:51 PM   #10
I put ceramic tile in my last bus. It looked great and the only cracking issue I had was was one tile that I had to notch around a doorway.
However.....
It was VERY heavy. I glued & screwed down two layers of 3/4 plywood and then glued & screwed down 1/2 cement backer board. Then I applied several coats of RedGuard. Finally came the tile put down with a mastic that was supposed to maintain some flexibility.
I don't think I will do it again.
Old 05-24-2018, 06:12 PM   #11
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
you can buy it BEFORE it's cut into strips? That's very interesting.
I have looked high and low and finally found something that is supposed to be able to hold up to almost the whole range of temperature and humidity that the bus will be exposed to.
Calibamboo has luxury vinyl plank the pro version is supposed to tolerate ambient temperatures of 32-113 and relative humidity of 20-80. Nothing else claims that high of a range. The next best I found was 50-100 degrees and 40-80% relative humidity. You can't screw the cabinets thru the floor, but you should be able to screw them to the walls behind the cabinets or to the sides. You aren't supposed to screw anything thru any kind of floating floor application, but some of them tell you not to ever install it until after cabinets and this one will allow you to do it under the cabinets as long as you don't screw thru it.
It's on sale right now for $3/sq ft which is pretty good for this higher end spec'd flooring. If you pick it up in downtown LA you can save the shipping.
If we do end up using this, I will report back on it. The other candidate in the running is MetroFlor genesis which is on sale right now for $3.43/ sq ft. but it's the one with the 50-100 temperature range and MUST be installed after cabinets. that means you have to buy the expensive trim pieces and make a lot more cuts, etc.
if anyone else has detailed info about their flooring that they love, or about either of these two options, I would LOVE to hear it! The reviews are good for both but naturally none of them mention use in a skoolie as it isn't rated for that even though it seems to be better than most other options.
2martins is offline   Reply With Quote
