Old 04-22-2017, 12:39 PM   #21
Originally Posted by mmoore6856 View Post
Depending on the brand some comes from Springs read your label
Once its distilled it really doesn't matter where it came from.
Old 04-22-2017, 12:43 PM   #22
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
Wow those post sure brought out less than intelligent respondes drinking bath water and not drinking distilled it was about layout remember? I think we got some sick puppies here
mmoore6856 is offline   Reply With Quote
Old 04-22-2017, 01:14 PM   #23
Robin97396's Avatar
Yeah, we're all high on bath water dude. You're obviously a tap water drinker.
Robin
Nobody's Business
Old 04-22-2017, 02:11 PM   #24
Jolly Roger's Avatar
Engine: Detroit 8.2
I built my subfloor and used masking tape to do the layout.
Moved/changed the tape around several times until everyone was happy and then made the important framing marks (square corners and stuff ) through the tape to frame to.for the bathroom area/holding tank area you can drill a small hole and drop a piece of wire or a long screw where you want your shower or toilet drain and use that as a reference point to verify layout above with tank locations below.
Anything you can think of can be a reality that is only limited by your ability.
Or time or money or both.
The latter for me.
I always wanted to start a welding business and use the slogan that says if you believe it together we can achieve it.
But that's me dreaming again.
Good luck
Old 04-22-2017, 03:27 PM   #25
Robin97396's Avatar
Some of us don't have the time, money or skills, but we're still doing it.
Robin
Nobody's Business
Old 04-22-2017, 10:46 PM   #26
Old 04-22-2017, 11:27 PM   #27
Robin97396's Avatar
I thought it was going well. Want a hit of my bath water?
Robin
Nobody's Business
Old 04-22-2017, 11:37 PM   #28
Pass it this way please...
LincolnEcho is offline   Reply With Quote
Old 04-23-2017, 10:51 AM   #29
Cowboy wisdom...
"...always remember to drink upstream from the herd."
Old 04-23-2017, 03:05 PM   #30
Unless you want to recycle for other purposes like to use it to flush your toilet such as this ---> http://www.goodshomedesign.com/innov...jang-woo-seok/
Old 04-23-2017, 03:55 PM   #31
Robin97396's Avatar
That may be a toilet for someone with no kids.
Robin
Nobody's Business
Old 04-26-2017, 11:24 AM   #32
jpm9909's Avatar
Chassis: Thomas 140HS 84 pass
Engine: RE 5.9L ER6BTA230 w/ MT643 Trans
Thanks for all the feedback guys....
and don't make me get the hose out to settle this whole water debate thing! j/k
Anyhow, I've made a scale model of a bus (1/12th scale assuming a 40' bus).
So I can play around with the interior design and basically just satiate my need to hurry the F up and buy/build this thing!! ha ha (only 3 more weeks till I can start the auction process, yay).
The red are little models of the sink/stove - shower - washer/dryer, couch, etc.... just to get an idea of how much interior space I'll have since the goal is for fulltime living.
"Be kind, for everyone you meet is fighting a hard battle."
jpm9909 is offline   Reply With Quote
