Old 07-25-2013, 01:31 AM   #1
Year: 92
Engine: DT 466
leaking ceiling vents
Hello, been awhile since my last post. I have stripped the bus and taken out the ceiling. I used Buskote paint for my roof, for multiple reasons, but also to seal any leaks. Unfortunately, it is still dripping, not a lot, but a little bit from where the vents in my ceiling come down. I'm very anxious to move on to the next step, which is installing the new ceiling insulation. I do not want to take any short cuts. I'm not sure if its a leak, or just condensation, but if any of you have had a similar problem, I'd love to hear how you resolved the problem. Thanks, I'll post pictures for better clarifaction if needed.
jjhomeonewheels is offline   Reply With Quote
Old 07-26-2013, 01:26 AM   #2
turf's Avatar
Re: leaking ceiling vents
if your are heating or cooling the inside, then its probably condensation. if the bus air temp is about the same as the outside air, then you got a leak.
Turfmobile Build Thread
Old 07-27-2013, 01:57 AM   #3
Year: 92
Engine: DT 466
The bus is not being heated or cooled, it is an empty shell, and therefore is roughly the same temperature. I'm going to have to take the vents off from the top anyway to remove an old small bee comb, so then I'll be able to hopefully patch/calc any cracks that I see.
Old 08-01-2013, 06:24 PM   #4
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
Were any of the bolts ever over tightened and cracked the hatch? That happened to me, it was a very small crack. Also, are they both leaking? If not, try to switch them and see if it still leaks the same, or if you only have 1 try turning it around. Get another angle on where its coming from.
ThePimentals is offline   Reply With Quote
Old 02-24-2014, 06:50 PM   #5
Year: 92
Engine: DT 466
its been awhile, still have the same problem, its not leaking so much from the hatch as it is from the overhead fan vents.
Old 02-27-2014, 03:10 PM   #6
Also I have found that my vents are quick to condensate and they drop water from hanging low parts on the vent.
Running heating vents along ceiling bluebird90 Heating, Cooling and Appliances 2 07-11-2014 03:12 AM
leaking door window gbstewart Conversion General Discussions 5 07-29-2013 07:09 PM
Leaking Rain Through the Walls M1031 Conversion General Discussions 2 06-14-2010 08:14 AM
a/c freon leaking minibusser2 Everything Else | General Skoolie Discussions 2 08-23-2006 08:59 AM
Leaking differential . . . vonslatt Everything Else | General Skoolie Discussions 6 03-22-2006 08:46 PM
