Old 06-13-2010, 10:21 PM   #1
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Re: Leaking Rain Through the Walls
After my experience with the roof caulking (check my thread) I'd use roof caulking on the inside and paintable caulking on the outside to leave a cleaner, more paintable surface on the outside. Just my thought. Oh yeah, before caulking be sure there is no corrosion or rust on the panels. Use a rustproofing primer if you need to remove rust and start at the bare metal.
M1031 is offline   Reply With Quote
Old 06-13-2010, 11:08 PM   #2
Hi there, I had the same problem with one of my windows, when I took the insulation out I could tell that the water was coming in from the window on the outside and coming down inside the wall and coming out between the seams on top of the seat rail. Hope that makes sense..... Leslie
Doodlebug is offline   Reply With Quote
Old 06-14-2010, 08:14 AM   #3
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
viewtopic.php?f=36&t=5982&start=45
About 2/3rds of the way down....
Leaking roof or condensation? 1waxhat Conversion General Discussions 5 12-27-2016 08:24 PM
leaking door window gbstewart Conversion General Discussions 5 07-29-2013 07:09 PM
Rain Barrel/Rain Water Catchment waste-not wagon Skoolie Conversion Projects 14 12-17-2009 09:45 AM
a/c freon leaking minibusser2 Everything Else | General Skoolie Discussions 2 08-23-2006 08:59 AM
Leaking differential . . . vonslatt Everything Else | General Skoolie Discussions 6 03-22-2006 08:46 PM
