Old 05-16-2018, 11:14 AM   #1
Engine: 8.2L Detroit Diesel
Rated Cap: 64
Leaky Roof and Frustrated!
Hello all, i am New to the forum here. We converted a 1988 Bluebird. well it had a few small leaks up front, and I thought I got them fixed. It was the windows, Pulled them out, cleaned everything and sealed them when I put them back in. problem solved. I also sealed around the windshield, just for good measure. and everything looks great. Until we got some Much needed rain, and I found yet another leak! UGG! Well it is coming from the front of the bus up top, I cant find any holes.. So my question is, Do you think it could be coming from the roof seam or a rivet? I guess my next step is to put a sealer around every seam and rivet head on the bus until there is no more leaks. Just frustrated. Thanks in advance!
Tracy F.
Farm Bus is offline   Reply With Quote
Old 05-16-2018, 11:16 AM   #2
Chassis: Saf-T-Liner MVP ER
Tracy F.
If the school bus lights are still in place, that's almost certainly where the leak is coming from.
If not, I guess a hose-pipe test is in order.
Steve Bracken
Build Thread
Old 05-16-2018, 11:24 AM   #3
Rated Cap: 64
Thanks Twigg. those lights are definitely still there. I guess I should not have been so naive in thinking that they were sealed good. I will check that and let you know. Thanks so much!
Old 05-16-2018, 11:55 AM   #4
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Some buses have a vent in the roof above the driver as well. I know my thomas does. I had some water coming down through screw holes around my roof hatch, so i hit the screws on my roof vent up front too
https://www.skoolie.net/forums/f11/n...tml#post256987
My build thread - Started 3.2.18
jjhwick119 is offline   Reply With Quote
