Old 09-14-2008, 12:02 AM   #1
swinada's Avatar
LED Tail Lights?
I bought some LED Tail and marker lights and just wanted to make sure I'm not gonna kill them by just connecting to the old wiring? Can somebody tell me if they need anything special or can they just be connected in place of the old lightbulb lights?
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
http://picasaweb.google.com/swinada/BusPictures http://www.swinada.com/bus.htm
http://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 09-14-2008, 02:13 PM   #2
Year: 92
Coachwork: ford
Engine: 6.6 Ford
Rated Cap: 3
Re: LED Tail Lights?
That's the beauty of them, they just plug & play. Wham-bam! you're done!
I put $1700 worth of em on 6 of our work trucks. Needless to say I got in a wee bit of trouble for it, but they sure are perdy!
nevrenufhp is offline   Reply With Quote
Old 09-15-2008, 12:33 AM   #3
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
i hooked them up to the stock wiring on my 65 they look and work great! i think less power to run than a bulb? timbuk
Old 09-15-2008, 09:41 AM   #4
Year: 92
Coachwork: ford
Engine: 6.6 Ford
Rated Cap: 3
Right, they use about 0.25 to 1 watt, depending on how many LEDs are in it. Some of the fancy, super bright ones take up to 25 watts, but that's still less than the standard 1156 incandescant's 35 watts. The only thing you may possible run into, would be the flasher acting up. Some flashers need a specific load to flash at the right time. The cure to that is to run an electronic one, so no matter what the load is, it'll flash at the same rate.
Old 09-16-2008, 10:20 PM   #5
swinada's Avatar
thanks for the replies, just wanted to make sure dont wanna blow them, after all they are not cheap.
Running Lights and tail lights not working bapos Alternative Fuels | Electric, Propane, Wood Gasification, etc. 2 12-14-2011 12:32 PM
Tail lights,running lights not working putterspitt Conversion General Discussions 2 10-12-2010 06:19 PM
tail lights keith Classifieds | Buy, Sell, Swap 3 02-20-2009 12:16 PM
driveline, tip to tail and in between stories adamanderr Conversion General Discussions 12 01-20-2009 02:44 AM
tail light lenses westport_wayne Classifieds | Buy, Sell, Swap 0 09-02-2006 06:40 PM
