Old 11-03-2015, 12:06 PM   #1
less than favorable roads
Im trying to better understand where a bus can go, both a rear engine(forward control?) and a front engine.
Im hoping to use this for a toy hauler and camper when taking out the dirt bikes. I dont intend to go wheeling in the bus but it will end up on dirt roads.
I notice the front engine bus's are always pretty high off the ground which would help. but how is traction on a dirt road, or in something like soft sand? Does it do OK with the 4 wheels in the back?
I'm comparing it to what a 4x4 f350 could do with a big 5th wheel for instance. a 4x4 super duty could tow a 5th wheel through things sand or a wash without too much difficulty for instance. you would be unlikely to get stuck(though its possible).
And then how would the chassis hold upto adding a drive axle in the front, i know that last bit is a lot of work, but it may be my only option.
thank you
Lawrence
lordsporkton is offline   Reply With Quote
Old 11-03-2015, 12:26 PM   #2
austin1989us's Avatar
Chassis: TC/2000
Engine: Cummins 5.9TA
I went up a pretty steep dirt road last weekend. It did alright. I'm not too sure how it'd work on sand/mud/anything a 2WD truck would get stuck in.
I forgot to mention:
-It's a front engine flat nosed bus.
-9 windows.
-26' long.
-It's somewhere in the 7-10 ton range, most of that on the front axle. (I've gotta get it weighed again).
austin1989us is offline   Reply With Quote
Old 11-03-2015, 12:31 PM   #3
crazycal's Avatar
I have only owned one rear engine bus but many front engine buses. I think the front engine buses are better suited for dirt roads. Just make sure you have a solid transmission. I backed off the pavement once and thought I would need to have someone pull me back up onto the pavement. I am talking 6 inches.
I'm hungry!
You Gotta Let Me Fly
Old 11-03-2015, 12:37 PM   #4
Coachwork: IC
Chassis: CE300
Rated Cap: 32
For heavy duty dirt road use, I'd look for a shorter sized conventional dog nose bus.
Old 11-03-2015, 02:00 PM   #5
Engine: 190hp 5.9 Cummins
Dog nose front engine.
Nothing rear engine.
Old 11-03-2015, 03:01 PM   #6
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Old 11-03-2015, 04:23 PM   #7
bubb, the real one's Avatar
Coachwork: Thomas/International
Chassis: 3700
Engine: 7.3
measure the foot print of the tires
The only way to know for sure if you can go the same place as a f350 truck is to find the surface area of the tires that actually touch the ground and divide it by the weight of the bus.
my bus thread, http://www.skoolie.net/forums/showthread.php?t=8860&highlight=bubb
bubb, the real one is offline   Reply With Quote
Old 11-03-2015, 09:47 PM   #8
With a 2wd Tires will make a bigger difference where you can and cannot go than on a 4wd. So pony up the pesos to get the correct treads for where you want to take it.
CaptainInsaneo is offline   Reply With Quote
Old 11-03-2015, 10:34 PM   #9
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Busses should not be driven on sand, too much weight on too narrow of tires. It would be like trying to drive through a couple feet of snow. They however to ok on grassland, even mushey wet land as long as you keep your speed faster than one might like, and eventually you will get very stuck!
When taking a vehicle like a bus off road, especially without a locker in the rear, you WILL get stuck eventually and you will realize just how heavy a bus is.
On gravel and dirt roads school busses do ok. The ride is very rough, but 60mph feels perfectly safe.
I would also recommend a manual transmision.
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
Old 11-03-2015, 11:13 PM   #10
wunderhut's Avatar
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
This is the last time I got stuck...
No help from locking duals...
A Cat D6 dozer came in handy though.
wunderhut is offline   Reply With Quote
