Old 05-05-2017, 10:03 PM   #1
Chassis: BlueBird
Engine: 5.9 turbo diesel Cummins
Let me see your shower!!
I'm about to start construction on the shower portion of my conversion and would really like to see yours for possible ideas. I'm going to be using a galvanized tub for the shower basin but am concerned about the splash factor. What did you use on the floor and walls? Did you use tile? If so did you take any extra steps to prevent cracking? Or just any advice in general. Thanks guys and gals
Totallyskooled is offline   Reply With Quote
Old 05-05-2017, 10:27 PM   #2
Robin97396's Avatar
Those galvanized water troughs can be bought knee high or ankle high. Of course the knee high trough can actually be used for a tub, and there's less splash factor if you put a shower curtain in it.
Robin
Nobody's Business
Old 05-05-2017, 10:41 PM   #3
Chassis: BlueBird
Yeah Robin, mine is about calf high and I do intended to use a shower curtain while standing but I'm also interested in making a bench for sitting (the girlfriend says she needs it to be able to shave her legs. Lord knows I want her to be able to do that too!) I'm looking at ideas very similar to the picture I'm including.
Old 05-05-2017, 10:59 PM   #4
Robin97396's Avatar
That looks pretty nice. I had a little simpler installation in mind.
Robin
Nobody's Business
Old 05-06-2017, 01:33 AM   #5
Elliot Naess's Avatar
Engine: 5,9 Cummins
People, people, people. You must follow the rules. Mankind aspires to some degree of civilization, and even we skoolies -- rugged individualists though we be -- should do our part.
Regrettably, it is my duty to remind you of...
Section 22459.3 (a) 8], National Bathing Appliance & Washing Apparatus Code
No Shower or Bathtub must ever be shown, demonstrated, or displayed; in physical presence, or in photographic or digital representation; without a live Human present in the above, illustrating and demonstrating correct use of same, in complete accuracy pertaining to such use, as in actual end-user utilization by Consumers in the Field.
That is all. You may proceed.
Elliot
Old 05-06-2017, 02:32 AM   #6
Year: 91
Coachwork: BB
24 x 36" rv tub 6" off the wall. Hinged curtain rod
Elma is offline   Reply With Quote
Old 05-06-2017, 02:52 AM   #7
Chassis: BlueBird
Elliot I am so sorry for my disregard of .Section 22459.3 (a) 8], National Bathing Appliance & Washing Apparatus Code: I promise I will be punished for my reckless behavior.
Elma did you use anything to seal your tin walls and the wood used on the front? I have considered using wood for the bench but I am concerned with mold and rot... BTW it looks awesome. Great job
Old 05-06-2017, 10:13 AM   #8
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I built my own out of redwood. I built the walls laying down and coated with 4 coats of marine polyurethane.
Here are my original drawings.
The final is pretty close, although the door will hinge on the other side. Still have to build the door.
Dick
Old 05-06-2017, 10:14 AM   #9
Shambhala Tinbolle's Avatar
Rated Cap: 72 passenger
No Shower or Bathtub must ever be shown, demonstrated, or displayed; in physical presence, or ....
Elliot you are fun!!
Shambhala
Ontario Schoolie
Shambhala Tinbolle is offline   Reply With Quote
Old 05-06-2017, 12:18 PM   #10
Engine: 5,9 Cummins
Elma! Wonderful interpretation of the law! And what a cute kid! (I may be fun, but I'm also a "grandfather type".)
Elliot
Old 05-19-2017, 11:01 AM   #11
Year: 91
Coachwork: BB
Thanks everybody!
"did you use anything to seal your tin walls and the wood used on the front? I have considered using wood for the bench but I am concerned with mold and rot."
I just made sure everything overlapped and then used clear silicone on the screws and where the metal meets the ceiling/tub. Linseed oil on the cedar planks (unsealed around the edges) and a bath mat on the cork floor.
I think wood would be fine as long as it's coated and sealed.
Old 05-20-2017, 08:05 PM   #12
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Tin walls? NO thanks. I had enough of that in the Canoe Club. Stainless steel walls are NOT appreciative on naked backsides, despite how hot you have the water temp.
Old 05-21-2017, 10:50 PM   #13
Chassis: Thomas
Here's mine 32x32 from homedepot
Imgur: The most awesome images on the Internet
Jcrum is offline   Reply With Quote
Old 05-22-2017, 05:50 PM   #14
Originally Posted by Jcrum View Post
What wood did u use for the roof?
Iheartbus is offline   Reply With Quote
Old 05-22-2017, 10:57 PM   #15
Chassis: Thomas
Lowes
3.5625-in x 8-ft Raw Pine Wall Plank
Item # 821962 Model # R ECVG 8 PINPP
we just stained them
Old 07-12-2019, 04:44 PM   #16
About how much does this unit from Home Depot cost??
Mobobaddon is offline   Reply With Quote
Old 08-01-2019, 01:05 AM   #17
sportyrick's Avatar
Chassis: F33695
contact cement
I bent up a piece of SS for a base 24x32x6" high walls with a 4 inch step over entrance on one side if I remember correctly, cut 2x2's and screwed to wall curve at top and all, framed up the front and sides, screwed and glued thin paneling to the studs then contact cemented cheap plastic shower sheeting to the paneling for a nail less look. Been there for almost 15 years and still looks great. Hang that plastic a couple inches down over the SS base for drip free sides. Look at my pics and I think there is a few views of it. sportyrick
