Old 07-19-2016, 12:24 PM   #1
Engine: 5.9L Cummins
Lets talk roof vents.
So there are a lot of options on the market and a lot of them are quite expensive IMO.
Ive managed to track down the create-a-breeze fan from Fantastic Fans for $104 USD. By far the cheapest options ive come across. It only has "exhaust" mode, not intake.
For those of you with switchable direction fans, is it worth it? Any other recommendations? Do you find it a good idea to add on the additional protector cover? Any issues with our curved roofs?
-cycosis- is offline   Reply With Quote
Old 07-19-2016, 02:07 PM   #2
These basic DC fans are a simple two-wire setup. Reversing polarity should reverse the direction of the fan blades.
BusFiend is offline   Reply With Quote
Old 07-19-2016, 04:15 PM   #3
FlyboyHPD's Avatar
I'm going with the Maxxfan 7500K model. One at the front and one at the back of my 40 footer. Lots of different options out there though to meet just about every need.
1999 International AmTran, DT466E, MD3060
https://flyboyrv.wordpress.com/
FlyboyHPD is offline   Reply With Quote
Old 07-19-2016, 08:20 PM   #4
My PERSONAL opinion is that roof vents are great in nice weather, but if you're going to be using it when it's cold out they're a real pain. When it gets below freezing they start to drip condensation, and when it gets into the lower 20's and teens, they freeze shut. If you have sense enough to go where it's warm, you shouldn't have any problems (we don't have that much sense - we go where the grandkids are).
dadelay is offline   Reply With Quote
Old 07-19-2016, 08:22 PM   #5
This makes perfect sense. But how do you ventilate your bus in warm weather?
Old 07-19-2016, 09:18 PM   #6
roach711's Avatar
Rated Cap: 19
The Fantastic Vent is good equipment and if anything fails the company will replace the part/s free. Ours has multi speed and in/out but we hardly ever use it as an intake fan. I do like the multiple speeds though.
The add on covers are nice. Now I don't pay much attention to whether the vent is open in bad weather.
The Roach Motel
Old 07-23-2016, 08:38 PM   #7
BuSmith's Avatar
So, for those who don't put in a vent, what do you do? Plastic bubble? Patch it? What are the other common options?
BuSmith is offline   Reply With Quote
Old 07-23-2016, 08:55 PM   #8
FlyboyHPD's Avatar
I used to have a website address but I can't seem to find it right now. Google "RV Skylights". They have clear ones and smoke tinted ones. They are great for covering openings and allow great light to come in. Or just completely patch it over with 16-18 gauge aluminum.
Old 08-25-2016, 11:28 AM   #9
Year: 1978
Chassis: IH Loadstar 1600
Engine: 345 v8
Anyone who has bought/installed one of these Maxxair or Fantastic Fans have any issues with it not properly mounting due to the curvature of the BUS roof???
Trask97140 is offline   Reply With Quote
Old 08-25-2016, 03:43 PM   #10
Chassis: MVP
Engine: CAT 3116
I just installed a MaxxFan 4000k vent on Monday. I cut a new hole in the roof and mounted it with no problems at all. The curvature wasn't really an issue. I chose to also use a cover so I can keep it open and running 24x7 extracting the hot air.
Piersg is offline   Reply With Quote
Old 08-25-2016, 03:55 PM   #11
FlyboyHPD's Avatar
I had no problem at all with the curvature of my bus roof when placed down the centerline of the roof.
Whether you're using an existing hole or cutting a new one in your roof for the fan, this is some of the best sealant tape you can use.
EternaBond RoofSeal
Old 08-25-2016, 11:42 PM   #12
Year: 1978
Engine: 345 v8
Right on FlyboyHPD & Piersg. Appreciate it. Im going to either get a Maxxair, or Fan-tastic with the cover. Boiling down my choices, hopefully order a set up tomorrow.
Old 08-26-2016, 02:08 AM   #13
What about heat loss in winter through the vent ?
is that and issue or is good for circulation ?
Thanks.
pepepito is offline   Reply With Quote
Old 08-26-2016, 02:17 AM   #14
sammy's Avatar
Coachwork: Gillig
Chassis: Phantom Schoolbus
Engine: Detroit Diesel 6v92TA
EZ Tops World Wide manufacture acrylic and Lexan skylights and domes. I think this is the place to get the clear or smoked bubble style skylights.
sammy is offline   Reply With Quote
Old 08-26-2016, 10:28 AM   #15
For winter use, there are insulated "plugs" made to fit up into the standard vents. Work very well.
Old 06-29-2019, 06:16 PM   #16
Chassis: Carpenter SB 2508
Engine: Navistar DTA360 disel inline 6 cyl, 5.9L
Hey Tango - where can you get the winter "plugs" for the roof vents?
Kathy K
Kaklehr is offline   Reply With Quote
Old 06-29-2019, 06:21 PM   #17
Traveling
Make em from scratch.
Old 06-29-2019, 06:34 PM   #18
HazMatt's Avatar
Chassis: IH 3800, 8 window
If I were you, I wouldn't expect much in the way of an immediate reply.
What with taking chemo y'day, I suspect that he may well be otherwised focused...
But, yeah... Campfire crafts-time.
