Old 06-14-2018, 06:44 PM   #1
Engine: 466e
Rated Cap: its Yuge
Lexan over E hatch hole. Do I prime?
Removed the e hatch hole and cleaned up the metal. Should I prime before putting butyl tape down and the poly? Also should I try to use the same holes?
Thanks
Dave
MambaJack is offline   Reply With Quote
Old 06-14-2018, 06:49 PM   #2
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Prime AND paint. Use the old holes, too.
Old 06-14-2018, 07:01 PM   #3
Engine: 466e
Rated Cap: its Yuge
Great thx. I have butyl tape for below and dicorr self leveling for the top. Should that be sufficient?
Old 06-14-2018, 07:03 PM   #4
Thanks
Dave
Always prime/paint bare metal!
Old 06-15-2018, 09:52 PM   #5
its funny that you say that. my bus is made of some high quality steel. i cut a few holes out, tossed the scraps in the dirt and left them lie there for years. not a bit of rust on the cut edges. even the little spindly bits wern't rusted off.
having said that i still prime my cuts with some rustoleium metal spray paint.
Nachowarrior is offline   Reply With Quote
Old 06-15-2018, 11:09 PM   #6
Hmmm High quality steel usually rusts faster. I've got cold rolled and hot rolled and the cold rolled rusts immediately.
Old 06-19-2018, 10:11 PM   #7
Engine: 466e
Rated Cap: its Yuge
Order of operations
Got the edges all cleaned up and the metal primed and painted.
Trying to determine now the best order of operations.
I have butyl tape and self leveling sealant, which would be best under the lexan? Also i should put the lexan on and seal it first then paint the roof with tropicool -right?
Thanks in advance for any advise
Old 06-20-2018, 04:27 AM   #8
Mgulley82's Avatar
Chassis: 40' Saf-T-Liner MVP ER
Engine: CAT 3126 7.2L
I used butyl tape around the edges of my lexan
Dicor around my Hardware and also around the edges after mounted
Then I masked the lexan off (leaving a small edge unmasked) and painted the roof
No leaks
I also added some sheet metal to make
My opening smaller first
Mgulley82 is offline   Reply With Quote
Old 06-21-2018, 07:35 AM   #9
its made of the same kind 9f steel they make shipping containers out of afaik. it will get a sirface patina of rust, but wont ever really rust through, the patina actuallymprotects rhe underlying layers of steel from rusting.
this is why people that want to bury building structures cheap use shipping containers, bus shells, and train cars. i was surprised at how well it held up, but i digress.
to the op;
fwiw; i use foam strip plus compression for the best water tight seals on my roof, eg; the ac system has nothing more than four bolts and a 1inch thick strip of foam seal all the way around. i made 2x2 wood frame lagged in place for the supports. i used similar for my hatch seals, wish i would have done the same for the openings of the hatches, because it works pretty darn well, 8 might rebuild them someday.
Old 06-21-2018, 11:41 AM   #10
No leaks
Butyl tape, seam sealer, lap sealant- those are the weapons of choice for FIXING roof leaks! Or preventing them.
Old 06-21-2018, 11:49 AM   #11
Keep in mind that Lexan comes in clear or tinted and I will not be using clear for covering the hole. I'll use a piece of tinted and then mount my FantasticFan in the middle of it.
Old 06-21-2018, 12:28 PM   #12
Chassis: TC RE
Engine: 8.3L
I like that idea.
GaryC
Gustav is offline   Reply With Quote
Old 06-24-2018, 06:55 PM   #13
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
Oh, you are right on with not using clear. I installed a clear, non-tinted skylight. I am now building in an ez-bake oven
Nick
Old 06-27-2018, 05:41 PM   #14
Opening Lexan roof hatch?
Has anyone built an opening roof hatch with lexan??? The light and air are both ideal for me
mad.am.scientist is offline   Reply With Quote
Old 06-27-2018, 05:52 PM   #15
Issues with sealing against rain becomes an issue. The fan I plan on mounting in the Lexan does open for egress if needed. I think I'm leaving the front escape hatch in as it can be opened fore or aft for ventilation and the fan in the back hatch will draw air for circulation.
