Old 01-14-2016, 04:52 PM   #1
lifting bus/removing wheel wells
what could I do to remove the wheel wells on this baby? i want a nice flat surface, i was told i could put smaller tires but the the body will scratch the ground if i dont remove some of it, could i raise the bus like people raises thier trucks? is tht a thing?
carneiro1292 is offline   Reply With Quote
Old 01-14-2016, 07:33 PM   #2
Alan N's Avatar
Year: 1975
Chassis: Gillig
If you lift it enough to get rid of the wheel wells you might find it is a little unstable/tippy.
Interesting bus however. What engine and transmission does it have?
Alan N is offline   Reply With Quote
Old 01-15-2016, 02:48 AM   #3
all i have from the ad
"This 1997 Blue Bird bus was a church activity bus (the outline of the decals can still be seen) and it is in great condition.
The engine is a 12 valve P-Pump Turbo and Intercooler 5.9 Cummins 6 cylinder diesel that starts at the first bump of the key.
Allison automatic transmission
This is a Non-Computer No Fuss long lasting Diesel engine with low miles and lots of good life left in her."
u think itll be tippsy even with water tanks installed underneath and filled? would increase weight at the base keep it from being unstable?
Old 01-15-2016, 12:41 PM   #4
what if i got smaller tires and lifted it just a tiny bit? is tht even feasible? is it worth it, expesive? i just need a flat interier.
Old 01-15-2016, 01:01 PM   #5
Check out Ol' Trunts build of a '35 Chevy. That is just what he did.
Old 01-15-2016, 01:03 PM   #6
i think you could find a flat floor wheelchair bus cheaper than making one into it.
Turfmobile Build Thread
Old 01-15-2016, 01:15 PM   #7
Also...smaller wheels = lower top speed. Sometimes dramatically. Better run some numbers before chopping. You can do that here...(see the bottom section)...
Engine RPM Calculator
Old 01-16-2016, 04:37 AM   #8
how to i find ol' trunts build? is there a search function on this site? oh and its not just the flat floor tht im looking for, its also a flat roof which gives me more head space. Ive been looking for bluebird tc1000s but cant find any and am almost giving up.
Old 01-16-2016, 04:48 AM   #9
front
Old 01-20-2016, 08:16 PM   #10
is a reg suspension lift viable?
