Old 09-15-2012, 09:26 PM   #1
living out of a bus
im a new guy here, from utah . my wife and i have 12 acres of land in the mountains to live off grid, with 2 40 ft conex,s to one day build and live up there. but cant afford to pay a house payment and build are little retirment house in the mountains. so now we are thinking of getting the largest bus we can and raise the roof and add a couple slide outs and live down in the city during the week and drive 1.5 hours to our land on weekend to work on it. but im wondering what the bus to look for and for a good price. whats the longest made, best motors and trans to look for. any help i could really use. i can fab fairly well, certified welder and have built some rock crawlers and custom cars. so i think i can handle this , just need a little help on the way. thanks everybody
rancid0076 is offline   Reply With Quote
Old 09-15-2012, 10:08 PM   #2
Re: living out of a bus
It sounds like you have all the skills you need to do a bus conversion. You could end up with a SKOOLIE as your retirement cabin if you are careful with your design. READ, READ, READ, You will learn what works and what doesn't. Good luck with the project and welcome.
Old 09-15-2012, 10:44 PM   #3
Skoolies are 40' in length at most and Blue Birds are probably the best built. Look for a low mileage diesel with an Allison auto trans. They will outlive us both. These days you should be able to find a really solid unit for around 3-4 grand. School district auctions are a good bet and you can often find well maintained units that come with full maintenance records. The roof raising is actually pretty straightforward. My ex and I raised ours 19" which kept the peak below the 13' highway standard but yielded a lot of extra space inside. Can't help with the slidesouts, but as I recall, there a a couple of folks here who have taken that on. Do as much searching and homework as possible before you start a layout. Things like locating the major plumbing often dictate where everything else goes.
Welcome and best of luck with the build.
Old 09-15-2012, 10:56 PM   #4
i think to help with plumbing , i will have the kitchen and bathroom back to back in the center of the bus. and also run a urine seperating composting toilet.
Old 09-16-2012, 09:24 PM   #5
pipopak's Avatar
If you plan to go to a regular camping site they have all the connections on the driver's side (water, power, drain, etc). You may want to follow the standard.
pipopak is offline   Reply With Quote
Old 09-17-2012, 12:39 PM   #6
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
Your roof raise will be simplified if you buy a bus with vertical sides rather than tapered sides. Most if not all Blue Bird full size school buses have the straight sides. Some others, like my Crown have sides that taper inward a couple of inches.
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: http://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Old 09-18-2012, 03:38 AM   #7
This thread by Elliott Naess chronicles his project raising the roof of his bus, "Millicent":
http://www.skoolie.net/forum/viewtopic.php?f=9&t=1709
It actually looks sort of easy, although that's not meant to imply that it's to be taken lightly.
stonestatue is offline   Reply With Quote
Bus Living frank-id Everything Else | General Skoolie Discussions 4 01-10-2013 09:01 PM
Two men make RV living hip Xtevan School Bus News 4 01-17-2010 07:48 PM
Anyone drive a bus for a living? arfisher83 Everything Else | General Skoolie Discussions 3 05-16-2009 07:17 PM
Living as the bus rolls. SeanF Skoolie Conversion Projects 0 03-18-2009 12:32 PM
living out of a bus rancid0076 Skoolie Conversion Projects 0 12-31-1969 07:00 PM
