Old 07-23-2015, 06:14 PM   #1
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
Look at my drawers!
Not perhaps the best construction ever but... Accurate to within 1/32 inch...
Plywood is so much nicer to work with over OSB but 5 times thge price!
Zephod_beeblebrox2 is offline   Reply With Quote
Old 07-23-2015, 07:32 PM   #2
Good job!
Plywood is so much nicer to work with over OSB but 5 times the price!
this is true!
Old 07-23-2015, 07:54 PM   #3
Year: 1994
Engine: 466dt
Rated Cap: 59
The trick to getting the runners right is metal washers. If the wood is not quite right, washers space the runners nicely.
Old 07-23-2015, 07:57 PM   #4
Year: 1994
Engine: 466dt
Rated Cap: 59
The bottom drawer is ten inches deep by 18 inches long by 13 inches wide. That should accommodate plates and dishes held edgewise. I'll build a rack to hold them with a rubber buffer at the bottom.
Old 07-24-2015, 12:05 AM   #5
Year: 1994
Engine: 466dt
Rated Cap: 59
ID:	7922and the third drawer. Four more to go and I have to put the sides on too!
Old 07-25-2015, 05:54 PM   #6
Year: 1994
Engine: 466dt
Rated Cap: 59
ID:	7937 well, I got 6 drawer bottoms in place. The 7th... It turned out I had been given two right hand runners. Well, not to worry. It was generous of somebody too give me a pile of runners. I made two drawers from donated runners.
Old 07-26-2015, 11:17 PM   #7
Year: 1994
Engine: 466dt
Rated Cap: 59
ID:	7974the basics of my drawers. Wood, glue, screws
Old 07-30-2015, 07:31 PM   #8
Year: 1994
Engine: 466dt
Rated Cap: 59
ID:	8041and drawers done!
Old 07-30-2015, 11:05 PM   #9
Chassis: Blue Bird
Engine: ISC 8.3
The grain on the faces makes kind of a fun pattern. Are you going to paint over it, or keep the grain visible?
Old 07-30-2015, 11:18 PM   #10
Year: 1994
Engine: 466dt
Rated Cap: 59
It's going to be painted. The white will remain white but thge drawers will be purple likje thisClick image for larger version
