Old 03-07-2018, 11:09 PM   #1
Looking at a potential bus- is this too much rust?
Hi folks, this is my first post here. We are looking at this bus for a conversion. How much rust is too much? Do these pictures make you wince, or should we go for it?
Name:	20180306_103514 (1024x768).jpg
Name:	20180306_103658 (1024x768).jpg
Name:	20180306_103703 (1024x768).jpg
Also, anyone got any thoughts about this 2000 Cummins 5.9 24-valve?Click image for larger version
Name:	20180306_103233 (768x1024).jpg
Mars is offline   Reply With Quote
Old 03-07-2018, 11:19 PM   #2
Lots of threads on here about the engine - I have one in my 1999 Blue Bird. It's no power house, but as long as you recognize its limitations when you're operating it you should be OK. I would probably keep looking if you plan extensive mountain driving though.
The rust doesn't look too bad from what I can see - it looks like air ride suspension - that will give a much smoother ride than springs, although it will require slightly more maintenance.
TrailLifeBill is offline   Reply With Quote
Old 03-08-2018, 12:00 AM   #3
Jdawgsfanasty's Avatar
Attachment 19713
Attachment 19714
Attachment 19715
Also, anyone got any thoughts about this 2000 Cummins 5.9 24-valve?Attachment 19716
Doesn't look all that bad...I personally like Cummins...but yeah that bus Looks pretty clean
Jdawgsfanasty is offline   Reply With Quote
Old 03-08-2018, 11:31 PM   #4
Thanks for your thoughts. I am surprised by your answers, but pleased, because other than the rust, we like the bus. Now to make some decisions.
Old 03-09-2018, 10:22 AM   #5
2000 would have the dreaded "59" block.
Old 03-09-2018, 01:26 PM   #6
The only Cummins block "to fear" is stamped "53"...not 59. The 53 was cast in Brazil and did indeed have a host of well documented cracking issues as noted in the following statement from Cummins...
"Between 1999 and 2001, the Cummins 24v engine blocks with casting # 53 were manufactured by the Brazilian company, TUPY. The # 53 block casting has inherently thin water jacket walls that are susceptible to cracking."
Old 03-09-2018, 03:29 PM   #7
My mistake, site won't let you edit your posts. what's with that?
Old 03-09-2018, 04:16 PM   #8
brokedown's Avatar
Odd, I can edit my posts.
Edit: also, the 53 block prolbems tend to happen before the 100k mile mark. If you find one with 150k it's probably kosher.
Old 03-09-2018, 04:36 PM   #9
After a short period the edit option goes away. Go to any of your previous posts and see if you still can?
cummins 5.9, rust
