03-07-2018, 11:09 PM
Looking at a potential bus- is this too much rust?
03-07-2018, 11:19 PM
Lots of threads on here about the engine - I have one in my 1999 Blue Bird. It's no power house, but as long as you recognize its limitations when you're operating it you should be OK. I would probably keep looking if you plan extensive mountain driving though.
The rust doesn't look too bad from what I can see - it looks like air ride suspension - that will give a much smoother ride than springs, although it will require slightly more maintenance.
03-08-2018, 12:00 AM
Originally Posted by Mars
Doesn't look all that bad...I personally like Cummins...but yeah that bus Looks pretty clean
Sent from my VS500PP using Tapatalk
03-08-2018, 11:31 PM
Thanks for your thoughts. I am surprised by your answers, but pleased, because other than the rust, we like the bus. Now to make some decisions.
03-09-2018, 10:22 AM
2000 would have the dreaded "59" block.
03-09-2018, 01:26 PM
The only Cummins block "to fear" is stamped "53"...not 59. The 53 was cast in Brazil and did indeed have a host of well documented cracking issues as noted in the following statement from Cummins...
"Between 1999 and 2001, the Cummins 24v engine blocks with casting # 53 were manufactured by the Brazilian company, TUPY. The # 53 block casting has inherently thin water jacket walls that are susceptible to cracking."
03-09-2018, 03:29 PM
My mistake, site won't let you edit your posts. what's with that?
03-09-2018, 04:16 PM
Odd, I can edit my posts.
Edit: also, the 53 block prolbems tend to happen before the 100k mile mark. If you find one with 150k it's probably kosher.
03-09-2018, 04:36 PM
After a short period the edit option goes away. Go to any of your previous posts and see if you still can?
