Old 06-29-2012, 08:44 AM   #1
Re: looking at getting new to me skoolie....
it might be.. depends on what you actually want to use it for. you should find out the hours of operation, transmission type and so forth. the price looks to be normal for that type of bus sold by a dealer.
Old 07-01-2012, 10:26 PM   #2
roach711's Avatar
Rated Cap: 19
The new motor is certainly a big plus, but I'd also want to know the condition of the tires, brakes and transmission. Those are pretty expensive to replace. A new set of tires alone can run near $2000. Ask whether the seller can show you the maintenance records. If it's been well maintained it could be a winner.
Diesel engines generally have a much longer service life than gassers, but the bolt-ons (alternator, water pump, transmission, etc.) don't live nearly as long.
The Roach Motel
Old 07-03-2012, 12:53 AM   #3
Send a message via ICQ to mightybus
Welcome aboard. Looks like your bus has a great engine. Lots of pictures please.
mightybus is offline   Reply With Quote
Old 07-03-2012, 08:25 AM   #4
If you buy 12-22.5 tires and put them on, you will go faster than 55, cause the circumfrence of the tire is larger...
Old 07-05-2012, 09:42 PM   #5
Your red racer mower looks like it will fit in just fine! Go ahead--put a bath towel around your shoulders, drink lots of water and get a move on! Some of us old guys would like to see what you do to your bus while we are still on the right side of the grass!
Old 07-07-2012, 08:37 AM   #6
Congrats on the GREAT start! See, it wasn't that bad and it looks like your helper had a good time! Keep the sweat--er I mean pictures comming.
Old 07-08-2012, 10:08 AM   #7
I just called my wife "Midnight Special" and got hit...
don't try that at home...
Old 07-08-2012, 03:17 PM   #8
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Furnaces, stoves, and roof air conditioners are not cheap when you buy them new.
I would snap them up. A lot of roof airs are 13000 BTU. They are good enough to cool your bus, provided that it is not 100 degrees outside. Parking in the shade helps a lot.
Old 07-08-2012, 05:34 PM   #9
It might work for a "zone" say bedroom....skoolies have a lot of realistate in them unless your spin 8 foot 2x4's
Old 07-08-2012, 05:47 PM   #10
if they have been sitting a long time, the orifices can be plugged up, and possibly things like connectors in the circuit boards corroded. that is a chance you have to take if something is free. if you can test them before removal it would be best as parts are sometimes more than a good used one that works on cl., and you should always insist on seeing a cl item work before you buy.
New Skoolie Conversion and Old Skoolie Remodel jlhollowx13 Skoolie Conversion Projects 0 01-22-2013 01:41 PM
