Old 07-23-2012, 10:29 AM   #1
Re: Looking for a detailed electrical wiring diagram.
you should just buy a 50 amp automatic switch over for the genset to shore power. not very expensive
the panel you listed should work good, keep in mind that the fan might need occasional changing...
most people do not tie the inverter in to the panel, but you can with the right transfer switch wiring. some people with the really expensive inverters run all the 110v wiring through it.
Bluebird Wiring Diagram Tinez Everything Else | General Skoolie Discussions 3 05-25-2019 10:42 PM
wiring diagram source? syke Conversion General Discussions 3 05-13-2014 08:09 AM
Help: Need a wiring diagram bhays Alternative Fuels | Electric, Propane, Wood Gasification, etc. 8 03-09-2012 08:21 AM
Wiring Diagram El Mastodonte Conversion General Discussions 0 07-25-2010 12:45 PM
Need wiring diagram or source for same frank-id Classifieds | Buy, Sell, Swap 1 11-18-2007 10:41 PM
